Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-19-2007, 12:58 PM   #1
JerryL
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
JerryL's Avatar
Default A big thanks to RPM Transmissions
RPM just finished installing the TH400 in my car. This conversion is not a "bolt-in", it requires custom parts and opening up the tunnel. We're still running the IRS but the differential has been beefed up. The transmission and converter are custom units built by Coan Racing. I'm running a Precision Performance Products air shifter. The transmission has a pro-type trans-brake set up through a fully adjustable 2 step. It will likely be a couple of weeks before any track testing but I was able to make 3 data-logged launches in Rodney's driveway. Data shows no appreciable hesitation (my original problem) and the brake seems to release instantly.
So why the TH400? From my own track experience I don't believe it's possible to be competitive on a pro tree with a 4L60 type transmission. The transmission running through an IRS is slow (relatively speaking) to react. Most of the guys in the Corvette Challenge Pro 10 are deadly on the tree, you can't afford to give them .03 - .05 at the start. The TH400 can be built to be almost bullet proof. The downside is loss of streetability, among other things there's no overdrive on the 400.
For those running an automatic transmission I'd say a 4L60 type from RPM will satisfy most, even on the high horsepower applications. If you're racing on a full tree (versus the pro tree) there's no problem. I know there's a potential weakness in the overdrive unit, many of us were running the 4L60E without the overdrive. It will be interesting to see how the new 4L80s work out.
Anyway, if you need advice on any type of transmission issues you won't find a better place then RPM Transmissions.
__________________
02 Z06
Cartek forged 427 (LS7): Callies crankshaft, Manley rods, Diamond pistons, ETP 240 heads, Jesel shaft rockers, NX direct port fogger, NX Maximizer, LSX Fast Intake, Kooks headers & X-pipe, Meziere water pump, Coan TH400 & converter with pro trans-brake installed by RPM, CCW drag package, Line-lock, Neverlift roll bar, American Super Car Challenge Serious Street Champion 2005 & 6
JerryL is offline   Reply With Quote
Old 08-19-2007, 02:06 PM   #2
Tsab
CF Senior Member
Tsab's Avatar
Jerry, an air shifter? That must be super trick man Sounds like the Pro 10 competiton just got tighter. I guess you won't be driving the car downtown for a cup of coffee anytime soon?
Tsab is offline   Reply With Quote
Old 08-19-2007, 04:26 PM   #3
JerryL
CF Senior Member
JerryL's Avatar
Tom,
The air shifters are common in pure drag race cars. I have the same type in my super gas Cavalier shifting the Powerglide.
__________________
02 Z06
Old 08-19-2007, 09:09 PM   #4
Tsab
CF Senior Member
Tsab's Avatar
I like it I'll have to check out the set up next time at the track.
Old 08-19-2007, 10:37 PM   #5
asmokegars
CF Senior Member
St. Jude Donor '03-'06-'07-'08
asmokegars's Avatar
Congrats on joining the turbo400 club. You will love it I'm sure. What gear are you running in it. I have a 3.42 and have been toying with a 3.15.
asmokegars is offline   Reply With Quote
Old 08-20-2007, 12:04 AM   #6
Paul_Z06
CF Senior Member
Paul_Z06's Avatar
Well, you either race or you phuck around...... I quit phucking around after the first unsucessful "season"
Paul_Z06 is offline   Reply With Quote
Old 08-20-2007, 07:59 AM   #7
JerryL
CF Senior Member
JerryL's Avatar
Quote:
Alan,
3:42 with a 2.75 first gear in the 400.
__________________
02 Z06
Old 08-20-2007, 10:37 AM   #8
asmokegars
CF Senior Member
asmokegars's Avatar
Quote:
Originally Posted by JerryL View Post
Alan,
Very nice Jerry!
Look forward to seeing you run that combo. I think you will be an even more formidable competitor.
Old 08-20-2007, 10:41 AM   #9
Emuffinman1
CF Senior Member
Emuffinman1's Avatar
RPM is the best! Jerry, good luck at the track. Paul
Emuffinman1 is offline   Reply With Quote
Old 08-20-2007, 04:20 PM   #10
STEALTH 99 C5
CF Senior Member
STEALTH 99 C5's Avatar
Good luck with it Jerry , an RPM built 400 should be indestructable . Are you going to Carlisle ?
__________________
Cartek-Home of the First 9-sec All-Motor C5 ,http://s170.photobucket.com/albums/u...ealth998-1.mp4
99 C5 FRC
Best ET-8.87 Best MPH-158.63 , 3700+Lbs
Cartek 402, Cartek/STS Rear-Mount Single 88mm Turbo .
RPM 4L80E Transmission+RPM 3.42 Diff
STEALTH 99 C5 is offline   Reply With Quote
Old 08-20-2007, 05:18 PM   #11
NICK YOSKIN
CF Senior Member
St. Jude Donor '08
NICK YOSKIN's Avatar
todd and rodney are awesome!
__________________
NICK YOSKIN is offline   Reply With Quote
Old 08-20-2007, 09:50 PM   #12
JerryL
CF Senior Member
JerryL's Avatar
Quote:
Thanks Mike. Weather permitting I'll be there on Friday.
__________________
02 Z06
Old 08-20-2007, 09:51 PM   #13
tensecvet
CF Senior Member
tensecvet's Avatar
Nice Job Jerry RPM sounds like they did you right
__________________
Thanks - Eddie "the Kid" Monari -Competitive Wiring (Wayne Keegan)- Carroll's www.rodandracecraft.com - Bammann Race Engines - RW Trans - Joe Gambino - Cartek Racing for my street car -
Respect ALL - Fear NONE
Rest in Peace Leo Barnaby III - NeverLift your friendship http://www.youtube.com/watch?v=_o1egC46TQA
tensecvet is offline   Reply With Quote
Reload this Page A big thanks to RPM Transmissions
Tags
conversion, rpm, th400, transmissions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 72 11-21-2011 03:50 PM
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Four Speed Auto vs Six Speed Auto Tallman C6 Corvette General Discussion 73 07-15-2005 11:33 AM
Any numbers from a before and after LS2 edit? jimman C6 Tech/Performance 73 06-03-2005 08:09 PM
big blocks and 5 speeds (or 6 speeds) need-for-speed Engine Mods 32 01-28-2003 09:00 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
