Quote:
Originally Posted by BrianG01
And it is killing my times...The absolute best 60' time ive had was 2.189
This is on a 99 with the mods listed in my signature with the stock size tires (michelin polot sport a/s)
Incase you have signatures turned off:
1999 z51
gm hot cam
Dyno tuning
dynatech long tubes
slp high flow cats
corsa catback
vararam
I suspect the track is Capitol Raceway and you raced Friday night. If that's correct, then there are two issues to consider.
(1) Capitol sets up the staging line in a manner that requires special care by the driver to avoid getting the tires wet. Can be done; I did it routinely there before I was banned. Just need to swing wide around the water. If you drive thru it, your tires will still be damp when staged. Even if you do a burnout, the distance to the tree is very short and your heated-rears will move thru the damp tracks left by the fronts. That harms traction.
(2) Friday nights at Capitol are widely attended by drivers new to the track and few on drag radials. The starting line and first 30' of the track are are usually damp. 60' times always suffer on Fridays.
Bottom line, Correct for (1) whenever you go to Capitol and avoid Friday nights if fast times are the goal. Traction there is substantially better on Saturdays, race day.
Ranger
