Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-16-2007, 08:07 PM   #1
Jeenis
CF Senior Member
Support Corvetteforum!
Default Driver Mod help!!
I seriously suck at launching. so much that i'm ready to throw an A4 in my z06. video of 4 runs. i was letting off on first 2 runs, third run, you can hear clutch slipping whole way down, 4th run my best ET and trap, but only 1.8 60'. from the burnouts and launches, please help me fix the driver mod. i'm not too worried about the ETs, just wanna get my 60's down and consistent. i don't get much seat time since Ennis, Tx is only open 1 or 2x a month.
launches are at 5000rpm, 14psi heated BFG 315/35/17, mods add up to 562 rwhp, clutch is exedy twin disc. thanks for any help/suggestions. don't laugh too hard at the vids, i excluded my stalls on 2 burnouts
Jeenis is offline   Reply With Quote
Old 08-16-2007, 10:13 PM   #2
jpee
CF Senior Member
jpee's Avatar
From looking at the video it appears you are letting the clutch out when you SEE GREEN ? If thats the case, you should be letting the clutch out on the last yellow... However no matter when you let the clutch out it will have NO effect on your 60' time... and if you are using "STREET" tires a 1.80 is a good 60' time..
The car sounds good, and I really cant tell if your clutch is slipping after you shift to 2nd & 3rd... From what I see on the videos all you need is more seat time... and if you are using street tires I doubt you'll get much better 60' times until you switch to Drag Radials..
Try leaving on the last yellow especially if you ever enter eliminations...
Good luck
__________________
John Panuzzo
"When I die, I want to die like my grandfather, who died peacefully
in his sleep. Not screaming in panic like the passengers in his car."
05 C6
Best ET 11.98 @ 117 mph
Vararam, 160 T Stat & Tuned By Cartek
2004 NHRA Div 1 Finalist
jpee@comcast.net
Join the Corvette Challenge
I LUV INSANITY RACING.........
jpee is online now   Reply With Quote
Old 08-16-2007, 10:41 PM   #3
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
[quote=Jeenis;1561530152]
I'm don't know why you didn't break something.
Way to low an air pressure, I would run around 30 psi. Low tire pressure will cause the tires to cup at launch only putting the outer edges on the track.
If this is a true dynoed RWHP, no matter what you do it will be hard to get the car to 60' without slicks and chassis work and at that piont you'll start braking parts.
mackeyred96 is offline   Reply With Quote
Old 08-17-2007, 12:18 AM   #4
Ranger
CF Senior Member
Ranger's Avatar
Opinions vary. Here is my take.
In my testing of BFG 315.35.17, spinning them in a parking lot at various psi from 24 to 12, they begin to cup at about 15 psi. But I'd suggest running 18 psi (hot); readjust the psi before each pass. That pressure will help absorb some of the shock on launch and shifts.
They won't handle a launch much above 4200.
Traction System Off, that's one push of the console button.
The burnout procedure is here: Burnout Without a Line Lock Also suggest watch the two C6Z vids under "driver cred." They show the burnout. You need to be very careful with the water and the positioning of the rears. Opening the door to look at the rear tire helps (1) avoid too much water and (2) starting the burnout in the correct spot, which is just forward of the damp area.
The launch procedure is here: General Launch Techniques You're seeking about five feet of wheel spin, a hook and then an explosive rpm climb. That will be achieved by the right launch rpm, fast clutch release, and a throttle squeeze calibrated to avoid breaking the tires loose again.
Finally, I would suggest not intentionally slipping that dual-disc clutch.
Ranger
__________________
'06 Z06 red 300 passes
Bone Stock Stock Tires……11.02 127.25 1.70 video
Bone Stock DRs......….…….10.71 130.32 1.60 video
'02 Z06 350 passes
Bone Stock Stock Tires……11.81 117.26 1.78
w/ CAI & DRs………...........11.52 120.21 1.64 video
My PRs Burnout Launch Shifting Clutch Care
Ranger is offline   Reply With Quote
Old 08-17-2007, 04:04 PM   #5
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I agree on the rear PSI.
I think your first burnout may have been a little too long, the 2nd one too short, & the third one a tad too long.
You're slipping the clutch too long (1st & 3rd launch), probably causing it to glaze/overheat, causing it to slip....
Looked like the 2nd pass you were headed towards the center line pretty far as well....Not ripping you, just telling what I saw....
How is track prep usually at that track??
Ron
__________________
09Z06Bone stock on DR's
10.750@128.19,1.563 60'@MIR,MD 3/25/11
Timeslip, 10.79Video
06Z06 M.S. Bone Stock
11.242@122.38, 1.688 60' @ Atco,NJ 11/17/06
Bone Stock on DR's
10.912@126.32,1.62 60' 12/5/08@Atco,NJ
Black 03ZO6
RPS clutch,Hurst,160* tstat, headers,Vararam, LS1 edit tuned, RPM trans & DTE brace all @ECS.
Best Pass: 11.21@122.30,1.58 60' 11/18/05 @ Atco,NJ. Slip
Best Street tire Pass: 11.67@119.3,1.711 60' 10/17/03@ Atco,NJ w/ a Vararam & Tune only
Dr.Ron is offline   Reply With Quote
Old 08-20-2007, 11:48 PM   #6
KyleBst264
CF Senior Member
KyleBst264's Avatar
Send a message via AIM to KyleBst264
With my stock C5Z, it took alot of practice and patience. I was given alot of advice from Ranger and TurboZ06, and it helped greatly. After alot of messing around, one day it just all clicked. My 60' went from mid 1.90's to consistent low 1.80's then down to low 1.70's and my best being 1.664. Repetition is def my friend. I bracket race my car every week, '06 was a learning year for me. But about 1/2 through this season I started being able to get good consistent reaction times in my car, it wasn't easy to learn, but I kept practicing and never gave up. Every test and tune I could go to, I went to. My driving has become very consistent over time as well, I can make 2 passes in a row and it's not unusual to have no more than a 3 hundredths difference between the two. Right now I'm 10'th in NED St Pts, but I'm gonna be the first to tell you, it was a long road for me, lots of practice and patience. It was alot of hard work. This is the first manual trans car I've ever owned, I've been bracket racing automatics for the 5 years before that.
KyleBst264 is offline   Reply With Quote
Reload this Page Driver Mod help!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Blink Blink CHMSL Mod Buster1 C6 Tech/Performance 15 10-12-2005 02:52 AM
Female C4 owners need your help, please post a response. lspalding C4 General Discussion 38 10-26-2003 12:59 PM
1st vette, need mod help bigsmatty C5 Tech 12 02-28-2003 01:10 AM
I Don't Get The PVC Mod..... FYNL4 C5 Tech 45 01-15-2003 05:27 PM
Vararam as first mod REDLYNER C5 Tech 34 05-20-2002 10:27 PM
Urgent help/advice needed - Z06 with 695 miles needs a new engine B-Myster C5 Tech 55 03-21-2002 02:22 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
