Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-25-2007, 08:18 PM   #1
c5man99
CF Senior Member
c5man99's Avatar
Default Tubes for CCW's
Can anybody tell me what brand and part # for an inner tube that will work with my 16" CCW drag package and MT ET Streets (26x11.5x16).
Thanks,
__________________
MF Racing
Marc Fisher
"Bat out of Hell"
10.78@129.00 1.46-60'
"All throttle, No bottle"
I'm not speeding, I'm qualifying.
NCM #5777
NHRA #370182
F230
c5man99@verizon.net
c5man99 is offline   Reply With Quote
Old 06-25-2007, 08:27 PM   #2
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
I'd ask that you to rethink that, I feel tubes can be very dangerous.
mackeyred96 is offline   Reply With Quote
Old 06-25-2007, 08:40 PM   #3
c5man99
CF Senior Member
c5man99's Avatar
Quote:
Why? My rears are screwed to the rim and in order to get the ET streets to wrinkle, you need the tube. I need the extra traction....I am running 13Lbs and use QA1's at all corners.
Old 06-25-2007, 09:54 PM   #4
mackeyred96
CF Senior Member
john mackey
Quote:
OOOOK IF YOU SAY SO.
PS, my tires are screwed without tubes and 13 lbs.
SEE BELOW.
__________________
John Mackey, National Corvette Museum Drag Racing Coordinator, Thanks to Carrolls Rod & Racecraft, Reher-Morrison Racing engins (412ci), Hughes PG. 9.797 @139.92 1.355 60'
Old 06-25-2007, 10:01 PM   #5
c5man99
CF Senior Member
c5man99's Avatar
SEE BELOW.
Not 26" ET Streets, are they!
__________________
MF Racing
Marc Fisher
"Bat out of Hell"
NCM #5777
NHRA #370182
F230
c5man99@verizon.net
Old 06-25-2007, 10:32 PM   #6
sixspdvet
CF Senior Member
sixspdvet's Avatar
I run the same tire, w/tubes and screwed as well.. I was under the same impression when I got mine.. I don't think you need the Tubes. It just adds weight and the screws won't go all the way through.. and if you think they will just add a small washer ..
Plus you have to drill out the hole for the valve stem..
I would have to agree with John on this...
Ernie
sixspdvet is offline   Reply With Quote
Old 06-25-2007, 10:36 PM   #7
black knight 06
CF Senior Member
black knight 06's Avatar
Hey guys, what do you mean " the tires are screwed to the rim"
thanks
black knight 06 is offline   Reply With Quote
Old 06-26-2007, 10:11 AM   #8
Fuzzy Dice
CF Senior Member
Cruise-In IV Veteran
Fuzzy Dice's Avatar
Quote:
thanks
As I understand it, you drill holes around the lip of your rims and insert screws into the holes....these screws grab the tire inside and prevent it from moving on the rim at launch...this, in turn, allows the tire to wrinkle or fold at launch resulting in a better hook and short time...
Fuzzy Dice is offline   Reply With Quote
Old 06-26-2007, 04:34 PM   #9
Face
CF Senior Member
Face's Avatar
Send a message via AIM to Face
Why is that>?
I put screws in my CCW's due the the tires spinning on the rim up to 1" each pass. Plus after having a friend suddenly lose all tire pressure in one of his tires after getting off his trailer(screwed and no tube), I decided to go with tubes.
Face is offline   Reply With Quote
Old 06-26-2007, 05:32 PM   #10
c5man99
CF Senior Member
c5man99's Avatar
[quote=Face;1560836969]Why is that>?
QUOTE]
Can you please tell me which tube maker, part #, price, retailer you got them from?
Thanks,
__________________
MF Racing
Marc Fisher
"Bat out of Hell"
NCM #5777
NHRA #370182
F230
c5man99@verizon.net
Old 06-26-2007, 06:19 PM   #11
sixspdvet
CF Senior Member
sixspdvet's Avatar
Goto the MT web site.. Item # 9555
Old 06-26-2007, 06:31 PM   #12
c5man99
CF Senior Member
c5man99's Avatar
Thanks all..............got the info I need.
__________________
MF Racing
Marc Fisher
"Bat out of Hell"
NCM #5777
NHRA #370182
F230
c5man99@verizon.net
Old 06-26-2007, 09:54 PM   #13
Major Spray
CF Senior Member
Major Spray's Avatar
If you are going with the tubes make sure you put a ton of baby powder on them to avoid them sticking to the rim and tearing. You will find the tube to fit a little tight on the 16 inch rim. They work but having tried it both ways I prefer no tubes.
Major Spray is offline   Reply With Quote
Old 06-30-2007, 10:46 PM   #14
c5man99
CF Senior Member
c5man99's Avatar
Quote:
Thanks for the info, John. I spoke with John at CCW and have desided to go without tubes and try the 28x12.5x16 ET streets. With my new top end (from the upcomimg Ls3) I will need as much traction as possible. I have removed the rear liners hoping this will give me enough room. Any thoughts on this?
Thanks,
__________________
MF Racing
Marc Fisher
"Bat out of Hell"
NCM #5777
NHRA #370182
F230
c5man99@verizon.net
Old 07-02-2007, 02:24 PM   #15
kromberg
CF Senior Member
kromberg's Avatar
Quote:
Originally Posted by Face View Post
Could you make a template of the screw holes? I am thinking about drilling my CCWs, but I am a little on where to drill them. I would hate to destroy a good set of rims.
Keith
__________________
Y2K C5
Pewter Exterior / Black and Grey Interior
420 rwhp / 411 rwtq - 12.431 @ 110.79 mph - 1.8871 60' at 5800' ( Old 383 Setup )
List Of Mods
Pics of 402 Stroker with A&A F1-R Procharger Buildup
kromberg is offline   Reply With Quote
Old 07-02-2007, 09:25 PM   #16
Face
CF Senior Member
Face's Avatar
I used the bolt heads as a reference.
Old 07-02-2007, 11:25 PM   #17
mackeyred96
CF Senior Member
john mackey
Can anyone here tell me why TUBES are dangerous?
I just want to see if anyone understands.
Old 07-03-2007, 09:24 PM   #18
c5man99
CF Senior Member
c5man99's Avatar
This a quiz? Any prizes !
From what I have been told by MT and John of CCW, If the tire moves on the rim, you will sheer the tube valve stem. That is why you MUST screw the tire to the wheel. Now, as far as CCW wheels for C5, Viper and Supra, The offset does not alow for proper placement of the tubed valve stem. According to John, a tube could be used but it would require 20+ Lbs. and still not be uniform within the tire. Also, Paul Major mentions using powder so the tube does not adhere.
__________________
MF Racing
Marc Fisher
"Bat out of Hell"
NCM #5777
NHRA #370182
F230
c5man99@verizon.net
Reload this Page Tubes for CCW's
Tags
ccw, tubes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Are 10sec 1/4 mile times for $5000 possible-No NOS VettesandZs C5 Tech 44 05-07-2004 03:42 AM
LGM LONG TUBES AND LGM 6 PISTON CALIPER BOUND FOR POCONO John Shiels C5 Tech 23 04-23-2004 06:17 PM
AWESOME DAY AT THE TRACK(MIR)....10's all motor!!!!!!!!!!!!!!!!!!1 Phil97SVT C5 Tech 57 11-12-2003 10:08 AM
1.773 @ 117.03 in 3gun's car J-Rod C5 Z06 Discussion 9 11-03-2002 03:11 PM
here goes the "nevrenuf" mods bonanza on my 2002.... hope to finish in a week! nevrenuf C5 Tech 81 10-22-2002 02:27 PM
CCW DRAG SET UP FOR SALE LG LONG TUBES 1 3/4 RACE COLLECTOR & OFF ROAD PIPE Chris Campi C5 Parts for Sale/Wanted 14 09-03-2002 03:42 AM
My new Viper [pic's] ElDiablo Northeast 35 03-07-2002 02:47 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
