Pro Topline 235 cc aluminum heads, fully race ported and flat milled to 56 cc chambers with 2.08/1.60 valves and > .700 lift springs
Solid roller cam with 261/270 degrees .050 duration and .625 lift (about .660 with the 1.6 ratio rocker arms)
Edelbrock Super Victor 2825 CNC ported intake (that's a $550+ intake)
1.6 ratio roller rockers, stud girdles
Balancer is a light weight Romac SFI 18.1 balancer
approx. 13.5 : 1 compression
Engine was just broken in on the dyno and was dyno tested and dynoed in at 590 HP and over 600 ft/lbs of torque with 1 5/8 headers.. The engine will make over 600 HP with large tube headers.
Machine work, engine break in and dyno testing was performed by a very reputable local shop (NELSON BROTHERS). (I can provide phone and address of the shop to verify what work was done by them)
This engine should be able to take a 100 shot of nitrous.
Before the rebuild, I ran 10.35 @ 127.59 with this engine in my 3000 lbs '68 Corvette (on engine without nitrous).
This engine is complete from intake to oil pan. The carburetor used for the dyno runs is a 80514 Holley HP series 1000 cfm carb (annular boosters). A 1 inch HVH spacer was also used for the dyno pulls. The ignition used for the dyno pull was a 65000 Volt HEI ignition.
The carb and ignition are NOT included. The carb (which was tweaked especially for that engine) is available for additional $450 (that was a $770 carb when new and it's like new) and the ignition with the bronze gear is available for an additional $100. (brand new, only used for dyno pulls)
I'm selling this engine as I went with a 434 engine with a big shot of nitrous.
Asking $5499
__________________
1968 Convertible, yellow/black
10.07 @ 131.82 mph (spun a rod bearing on that run - would've been easily in the 9's without the spun bearing). The spun #1 rod bearing was also the reason for the rebuild..
