Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-22-2007, 08:30 PM   #1
93 ragtop
CF Senior Member
93 ragtop's Avatar
Default NHRA question
What can a conv. run with a 6 point rollbar? This is without a hardtop, just cloth and the bar.
__________________
93 Automatic White Vert. 4.09 gears, Yank 3000 converter, Hot Cam, ported heads, Exotic Muscle LT headers, magnaflow mufflers Meziere water pump, and professionally tuned by Alvin and it passes emissions!!
My best run 11.82 ET at 116.52 mph. and 1.66 60ft.
My wifes best run 11.71 at 117.31 mph.
362 rwhp
379 torque
93 6 speed White Vert. 383 with a rear mount 85mm turbo. water to air intercooler, 6 pt. rollbar. Gen. 7 dfi. and many more extras. No numbers yet!!
93 ragtop is offline   Reply With Quote
Old 06-22-2007, 09:02 PM   #2
dr.juice
CF Senior Member
dr.juice's Avatar
If I'm not mistaken, you can as low as 10.00 but not faster than 135mph.
dr.juice is offline   Reply With Quote
Old 06-22-2007, 11:57 PM   #3
427Hotrod
CF Senior Member
427Hotrod's Avatar
Uh oh...I'm in trouble.........
JIM
__________________
WINNER!! "FASTEST STREET VETTE IN TX." N/A-'03
R/U-'04
WINNER!! '05
Multiple High MPH and Low ET WINNER!
All Motor/Pump Gas 540", G-Force 5 speed, Custom Dana 60 IRS/3.07 gears
Best ET- 9.90 Best MPH-141.40
http://s318.photobucket.com/albums/m...rrent=Jim3.mp4
http://s318.photobucket.com/albums/m...rrent=Jim4.mp4
Club website:
http://www.nwhoustonvette-rods.com/
427Hotrod is offline   Reply With Quote
Old 06-23-2007, 08:28 AM   #4
93 ragtop
CF Senior Member
93 ragtop's Avatar
Quote:
That was what I was hoping for. Thanks for your help!!
__________________
362 rwhp
379 torque
Old 06-23-2007, 06:28 PM   #5
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Quote:
Sorry, guys. The fast limit is 13.50. At 13.49 you need a minimum 5 point roll bar. The rules are no different for a 6 point bar. At 13.49 you need an NHRA legal roll bar.
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 06-24-2007, 06:23 AM   #6
93 ragtop
CF Senior Member
93 ragtop's Avatar
Quote:
RACE ON!!!
Maybe I should add more info to this. I purchased a conv. vette which has a 6 point roll bar in it now. It has the door bar with swing outs. I was told it is a NHRA legal bar, and I assume it is.
My understanding, without a roll bar was 13.49 for a conv. and 11.49 on a hardtop. Then, if a 6 point NHRA legal bar was added to a hardtop, it was good for 10.00 et.
Now, here is my question.
"Assuming" it is a "Legal 6 point NHRA bar" is it ok to go as low as 10.00 et with a conv?
__________________
362 rwhp
379 torque
Old 06-24-2007, 07:48 AM   #7
16Again
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11
16Again's Avatar
Quote:
Yes My bad, i'm incorrect
***See the 2 answers below me as THEY ARE CORRECT*** The answer as described in the posts below, is located on page 21 of the 2007 NHRA Rule Book if you have one.
16Again is offline   Reply With Quote
Old 06-24-2007, 12:47 PM   #8
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
No. Sorry, I answered a question you didn't ask, above. The roll bar that is legal to 10.00 in a coupe is only good down to 11.00 in a convertible. A convertible must have a roll cage to run 10.99 and faster.
NHRA has specs for a roll bar. One of the specs is that be a minimum of 5 points. A swing out door bar is allowed. NHRA also has rules as to what ETs and car configurations require a roll bar. Whether the bar is chromoly or mild steel, 5 point or 6 point, with or without a swing out door bar, does not change or extend where it is required. I don't question whether your bar is legal or not. I had HUA syndrome when I wrote my first answer. I addressed how fast you could be before a roll bar is needed. You wanted to know how fast before a roll cage is needed. The information you added wasn't necessary, but it did serve as a wake up call for me. Sorry about the first, and I hope this helps.
RACE ON!!!
Old 06-24-2007, 01:27 PM   #9
Mr. Jean
CF Senior Member
Mr. Jean's Avatar
Jean Muntifering
On Converts, it's 10.99 / 135 mph. That or any quicker or faster and it's a Cage for you.
Mr. Jean is offline   Reply With Quote
Old 06-25-2007, 04:36 AM   #10
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
Convertables running 10.99 or quicker or exceeding 135 mph roll cage mandatory .
Roll bar mandatory in all cars (including T-tops)running 11.00 to 11.49,convertables running 11.00 to 11.49.
Cage mandatory for 10.99 or quicker or exceeding 135 mph.
__________________
Johnny Carson once said.A married man may live longer ,but is more willing to die.
REDC4CORVETTE is offline   Reply With Quote
Old 06-25-2007, 11:49 AM   #11
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Correction: ...convertibles running 11.00 to 13.49.
Also in the roll cage section, coupes are given a break from the cage requirement between 10.00 and 10.99 if they are full bodied and have an unaltered firewall, floor and body. I have paraphrased, slightly, so see the 2007 NHRA Rulebook for details.
RACE ON!!!
Old 06-26-2007, 07:17 AM   #12
93 ragtop
CF Senior Member
93 ragtop's Avatar
Thanks to everyone for all their help!!
I will add, I purchased a vette from fellow forum member "Bruce" which is the car I am refering too. It needs a little work, ie oil leaks, and the DFI system has not been tuned yet. It has a 383 and a rear mount 85mm turbo. Bruce made 544rwhp with a 14lb supercharger before going turbo, so the car has potiental. However it does have a stock diff, and a 6 speed, so those will limit the ET.
I have a hardtop from my other vette, but I do not know if it will clear the rollbar or not.
Again, I want to thank everyone for taking the time to answer my questions.
__________________
362 rwhp
379 torque
Old 06-26-2007, 08:36 AM   #13
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Hehehehe...............bring it Richard
Allthrottleandsomebottle is online now   Reply With Quote
Old 06-26-2007, 11:24 AM   #14
93 ragtop
CF Senior Member
93 ragtop's Avatar
Quote:
Oh believe me, you are on my mind. Look forward to seeing you and everyone this fall!!
__________________
362 rwhp
379 torque
Reload this Page NHRA question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Great news! New NHRA rules MikeV C5 Tech 21 06-25-2004 11:05 AM
Crazy Question: 9's / 150mph / Parachute / AIR BAG DEPLOYMENT????? JR-CRUZN-C5 Drag Racing 24 05-22-2004 08:45 PM
No change to the NHRA GLASS/T-TOP rules. mackeyred96 C4 General Discussion 26 09-04-2003 12:57 PM
Well its official... I might be the 1st NHRA legal 9sec C5 - car and driver! boweryboy C5 Tech 64 07-11-2003 03:10 PM
Coolant Temperature Sensor Question Tourney3p0 C4 Tech/Performance 26 06-23-2003 12:05 PM
Question 1: Big block vs Small block Atomic Fusion C3 Tech/Performance 55 11-07-2002 06:14 PM
Is your 11 sec. C5 NHRA legal? mongrel C5 Tech 40 04-14-2002 06:57 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
