Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-27-2006, 11:42 PM   #1
4DRUSH
CF Senior Member
4DRUSH's Avatar
Default Safe,Legal way to add Slow Down Weight
On a C5 coupe whats the legal, safe way to add weight to slow the car down alittle on a given day? ( Possibly 100 to 200 Lbs?)
4DRUSH is offline   Reply With Quote
Old 12-27-2006, 11:49 PM   #2
jpee
CF Senior Member
jpee's Avatar
You could let Chris (Insanity) drive it! That should have you covered..
Otherwise the weight should be bolted to the frame...
jpee is offline   Reply With Quote
Old 12-28-2006, 10:22 AM   #3
Face
CF Senior Member
Face's Avatar
Send a message via AIM to Face
Quote:
You mean a bowling ball in the cargo net would be a bad idea?
Face is offline   Reply With Quote
Old 12-28-2006, 08:15 PM   #4
Major Spray
CF Senior Member
Major Spray's Avatar
You are talking about a lot of weight. You want to make sure you put in the right places. I had to add two hundred pounds to my car to run in orlando is was no easy task. There are other ways to slow your car down.
Major Spray is offline   Reply With Quote
Old 12-28-2006, 08:55 PM   #5
vetteman9368
CF Senior Member
Gulf Coast Events Coordinator
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
vetteman9368's Avatar
Location: I have no tolerence for liberals and fools, but sometimes i repeat myself
Send a message via AIM to vetteman9368 Send a message via Yahoo to vetteman9368
Quote:
I have to add nearly 300 by the time I go to bradenton in Feb
vetteman9368 is offline   Reply With Quote
Old 12-29-2006, 07:08 PM   #6
Matt383
CF Senior Member
Matt383's Avatar
Location: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
I had to slow my car down last summer to run the 12 sec index in the MSD True Street.
Since I have multiple sets of wheels and tires I went with the heaviest set of wheels I had.
Then I short shifted at lower RPMS.
I went to the track and experimented with different shift points the weekends before the event.
Which was easy as all I did was change the pills in my shift lite.
Make sure to note what shift points give what results.
Just went to my log book. What worked best was short shifting by a few hundred rpm's.
(The shift lite makes it consistant) AND holding the rpm's at the high end.
As soon as I hit 5000 I held it there through the traps.
I made notes in my log book of runs where I held it at 5000, 5500, and 6000.
This will then make it easier to figure out what you need to run at when the time comes.
Very consistant!
My two cents. and good luck.
Matt383
Matt383 is offline   Reply With Quote
Old 12-29-2006, 11:16 PM   #7
eb02z06
CF Senior Member
St. Jude Donor '08
eb02z06's Avatar
Bro-why don't you just drop the shift points till the car just breaks into the 9's?
eb02z06 is offline   Reply With Quote
Old 12-29-2006, 11:28 PM   #8
4DRUSH
CF Senior Member
4DRUSH's Avatar
Quote:
I know. I locked up the PCM years ago & had to get new PCM and new LS1 edit cable. Since then I've been scared to do any tuning.
Maybe I'll just put some shims under the gas pedal if needed on certain days?
Old 12-30-2006, 03:43 AM   #9
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
I put 500 lbs of tools and stuff in the back of mine before I had the roll bar to keep me in the 12's.
mackeyred96 is offline   Reply With Quote
Old 12-30-2006, 09:55 AM   #10
Matt383
CF Senior Member
Matt383's Avatar
OK.
So now I'm confused. (which is an easy thing to do these days)
Just to clarify (again). Changing my shift points is a manual thing not programmed in. my trans is a T-400. Just keep my nose in the tach.
Just trying to help by sharing my experiences in slowing my car down to run an index consistantly.
By the way..I won the 12 sec class at MSD True Street this summer at Joliet/RT 66.
My three run average was 12.013
The car can run low 10's.
Matt383
Old 12-30-2006, 10:10 AM   #11
GrandSportC3
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VIII Veteran
St. Jude Donor '03-'06
GrandSportC3's Avatar
Send a message via AIM to GrandSportC3 Send a message via Yahoo to GrandSportC3 Send a message via Skype™ to GrandSportC3
Quote:
Originally Posted by Matt383 View Post
OK.
Matt383
I'd bet that you didn't run the spray too which also helps to slow down
GrandSportC3 is offline   Reply With Quote
Old 12-30-2006, 03:11 PM   #12
Matt383
CF Senior Member
Matt383's Avatar
Quote:
Yeah, you are right on that.
But, still it runs low 11's n/a.
The trick was to slow it down to a dailed in number, which takes some practice, which I guess is my point.
Matt383
Old 01-04-2007, 11:07 AM   #13
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In V Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
The other way..........turn TC back on AFTER your burn-out..........keeps things VERY consistant
Allthrottleandsomebottle is offline   Reply With Quote
Reload this Page Safe,Legal way to add Slow Down Weight
Tags
corvette, slowing, weight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
