Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-26-2006, 02:12 PM   #1
REDGAR
CF Senior Member
Cruise-In II Veteran
Cruise-In VI Veteran
CI VI Drag Champ!
Drag Race Event Coordinator
REDGAR's Avatar
Default Anybody try the Goodyear Drag Radials yet
http://www.racegoodyear.com/products/dot_drag.html
REDGAR is offline   Reply With Quote
Old 12-26-2006, 02:55 PM   #2
JR-CRUZN-C5
CF Senior Member
JR-CRUZN-C5's Avatar
Redgar - Looking over the Specs of the 315/35 - 17 I see some problems:
1. Short Sidewall.
2. 25.5" Height
3. 11.2 Tread
I think the high Horsepower Vettes will have a hard time "hooking" with this tire. I can hook with an ET Street 16 X 12.5 X 28 (10" Tread) and can't find a radial to match up. I tried Radials 16" @ 26" tall about 12" wide and when they broke loose they wouldn't rehook!!
JR
__________________
00 C5 Coupe-FLP 427 C.I. C5-R, AFR Heads, Lunati rotating assy., Comp Cam,Rockers,Lifters,Springs, ProCharger/F-1R (18.0 lbs.),Fast Int., FLT stage 7 A4,Kooks 1 7/8, Yank TC, RPM C6/Z06 3.42 Rear End, CCW Wheels, Vinci Shocks/Line lock, FLP BigStuff3, Motor City Mold Hood. Alston Race Cars Cage. ECS Driveshaft, Brackets & Pulleys (Dynos 800+ RWHP on 93 Oct.)
JR-CRUZN-C5 is offline   Reply With Quote
Old 12-26-2006, 03:01 PM   #3
REDGAR
CF Senior Member
CI VI Drag Champ!
REDGAR's Avatar
Thanks JR. it seems noone really makes a 16" radial in in the size similar to the 11.5 et street
Old 12-26-2006, 05:28 PM   #4
Tom Hall
CF Senior Member
Quote:
What about the 255-50-16 ET street radials? Steath 99 posted he had 1.36 60ft times with these tires.
I'm slowing down my car this year and I want to drive it to the track.
__________________
LS7 Crate Engine with 2" Stainless Works Headers.
Stock Engine. Best N/A. [10.71 @ 127mph]
Best N20 150 Dry shot 2nd and 3rd gear only.[10.12 @ 136 mph]
Sold Car
Tom Hall is offline   Reply With Quote
Old 12-26-2006, 05:45 PM   #5
REDGAR
CF Senior Member
CI VI Drag Champ!
REDGAR's Avatar
Those have to go on a 9" rim max the way I understand and we have 10.5" wheels
Old 12-26-2006, 06:08 PM   #6
JR-CRUZN-C5
CF Senior Member
REDGAR - According to the "Real Racer Guys" you try not to compress
your sidewall more than 25% (Usually varified by photos) and most of the 17" tires give up sidewall height. You and I need to soften the
"squat" and sidewall is what does that, letting us beat the snot out of
our "plastic toys" without much breakage. Until someone comes out with a 17" tire with a decent sidewall I'm not going to risk the damage. Even the 17" ET Streets gave up sidewall. Most guys run the 15" tires 29 - 31 tall with a TON of sidewall. We just don't have the fender clearance. One of the reasons I went to the 28" tall 16" ET Street was to improve the sidewall "give".
JR
Old 12-26-2006, 06:31 PM   #7
REDGAR
CF Senior Member
CI VI Drag Champ!
REDGAR's Avatar
Gotcha JR.
I was asking on these tires not just for me but to gather info for when soemeone asks about tire options. I think we might be switching the sled over to 28" tires next year as well.
Old 12-27-2006, 12:59 PM   #8
JR-CRUZN-C5
CF Senior Member
Redgar - If you do go to 28" then plan on getting rid of your rear fenderwell liners. I left mine in and wore rectangular holes in the forward side of both. Tossed them in the garbage, went to chevy bought another set and put them up in my garage attic for the next owner (when ever that may be).
JR
Old 12-27-2006, 04:14 PM   #9
REDGAR
CF Senior Member
CI VI Drag Champ!
REDGAR's Avatar
JR I had a set of 28"s on in the beginning of last year and already have those holes and cracks. I will be removing them too. Makes it harder to clean up the rubber mess though
Old 12-27-2006, 06:00 PM   #10
JR-CRUZN-C5
CF Senior Member
REDGAR-
I pretty much gave up on that - I now only do one or two local car shows each year, because I can't get it "show clean" anymore. I actually wait until the buildup is so bad that a "scraper" can peal it off! The wide tires even get burnout rubber on the lower & leading edges of the red side marker lenses (WD40 gets it off). I guess thats the price of "fame and fortune". Being that I'm a Coupe I even get tons of tiny stones up in the rear water trough. I wipe those out after every event. Boy the things we Vette guys have to endure!!!!!!!!!!!!!!! I was "toying" with designing and fabricating a set of "competition" rear fender liners that would work with the ET Streets, but I kind of like the access to "stuff" without them being there!!!
JR
Old 12-31-2006, 10:11 AM   #11
DSCHULTZ
CF Senior Member
DSCHULTZ's Avatar
I stuffed rags in the water trail to block the rocks and rubber from getting up there it worked.
DSCHULTZ is offline   Reply With Quote
Old 01-07-2007, 09:44 AM   #12
Tom Hall
CF Senior Member
I'm still looking. What about the M&H Drag Radials, P305/40/16?
http://www.mandhtires.com/store.php?...on=show_detail
__________________
Sold Car
Old 01-07-2007, 10:23 AM   #13
REDGAR
CF Senior Member
CI VI Drag Champ!
REDGAR's Avatar
Tom, those are bias ply.
I looked at their "radials" and they have the same 255 size for 9" rim.
Old 01-07-2007, 12:18 PM   #14
Tom Hall
CF Senior Member
I missed that. I think I may try them and keep the CCW Firestone bias ply tires on the front and see how it does. I don't want to trailer my car anymore or at least going to the local tracks. The 28 inch Hooisers don't drive very well on the street.
Tom.
Old 01-11-2007, 08:46 PM   #15
c5man99
CF Senior Member
c5man99's Avatar
Edgar, I tried the 16" ET street radials on my CCW setup last season....fit ok but they were NOT consistant. Do we have enough room to mount the 28" streets with the liner out? I worry about tearing off the quarters!
__________________
MF Racing
Marc Fisher
"Bat out of Hell"
10.78@129.00 1.46-60'
"All throttle, No bottle"
I'm not speeding, I'm qualifying.
NCM #5777
NHRA #370182
F230
c5man99@verizon.net
c5man99 is offline   Reply With Quote
Old 01-11-2007, 09:28 PM   #16
Face
CF Senior Member
Face's Avatar
Send a message via AIM to Face
Quote:
The liners will fall out or have a hole burnt through them before you lose a quarter.
Face is offline   Reply With Quote
Reload this Page Anybody try the Goodyear Drag Radials yet
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
