12-26-2006, 12:32 PM
CF Senior Member
Cruise-In VII Veteran
Let's see skinnies on front of C5??
What to see pic from side and see how far they stick out in relation to side of frt fender.
__________________
11.55 @ 118.12 mph Bolt On's
Cruise- In VI Drag Race Runner Up
Tuning done by www.GearsAreUs.com = Me
99 Vette Mag Red * 99 Vette Nassau Blue
93 Vette 40th formerly owned by Billy Ray Cyrus 10K miles 4 sale
99 Trans Am WS6 6 speed * 01 CTS Caddy
00 Custom Chopper 113ci
12-26-2006, 12:41 PM
CF Senior Member
Cruise-In II Veteran
Cruise-In VI Veteran
CI VI Drag Champ!
Drag Race Event Coordinator
Mine stick out a little but you wouldn't be doing these anyway unless you plan to change your brakes..they are 15's
12-26-2006, 02:15 PM
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11
16" CCW skinnies. This is the standard drag set-up.
This picture is The fearless leader Edgar Perez, driving my car in July. These are the only 2 pictures I have at the moment.
12-26-2006, 02:43 PM
CF Senior Member
CCW "Drag Package" dangling a bit though!!
JR
__________________
00 C5 Coupe-FLP 427 C.I. C5-R, AFR Heads, Lunati rotating assy., Comp Cam,Rockers,Lifters,Springs, ProCharger/F-1R (18.0 lbs.),Fast Int., FLT stage 7 A4,Kooks 1 7/8, Yank TC, RPM C6/Z06 3.42 Rear End, CCW Wheels, Vinci Shocks/Line lock, FLP BigStuff3, Motor City Mold Hood. Alston Race Cars Cage. ECS Driveshaft, Brackets & Pulleys (Dynos 800+ RWHP on 93 Oct.)
12-26-2006, 04:42 PM
CF Senior Member
Quote:
Originally Posted by
REDGAR
Edgar
going to put on F body frt brakes. what wheel are u using and backspacing on them?? how much do they stick out??
12-26-2006, 05:18 PM
CF Senior Member
CI VI Drag Champ!
Ah you are committing to smaller brakes...cool. Not sure what the size is cause I bought them used. I will look inside to see if it says anything.
They do stick out some....let me see if I can find you some more pitures
12-26-2006, 05:22 PM
CF Senior Member
CI VI Drag Champ!
12-26-2006, 11:41 PM
CF Senior Member
Mine don't stick out, they are not even as far out as stock.
12-27-2006, 01:32 AM
CF Senior Member
ICaughtVetteFever
Thanks but Looking for a wheel with alittle more bling bling!!!!!!!
12-27-2006, 04:25 PM
CF Senior Member
DragMan
Well, strip the paint and polish them(or chrome), heck, they were only $60 a piece with tires.
12-27-2006, 05:08 PM
CF Senior Member
CI VI Drag Champ!
60 a piece? What tires are on there? I presum you bought them used?
12-27-2006, 08:17 PM
CF Senior Member
REDGAR
In the pic are the tires that came with the wheels, the temp spares. So far they have not given me any trouble, but if you want to run with slicks you will need a bias tire to match. Yes, these were used from a auto recycler, plenty of them around.
12-30-2006, 11:08 PM
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
NCM Ambassador
12-31-2006, 02:59 AM
CF Senior Member
that is what I was taking about. Good Shots! What size on rear & size of frt tires?? Thanks!!!
Wish I could see after market Bogart skinnies like that!
01-02-2007, 10:37 AM
Cruise-In V Veteran
NCM Ambassador
DragMan
Std CCW bias ply fronts, 345/30/18 BFG drs
I drive 50 miles to the track, lower the tire pressure, crack off 1.49 60's and 10s.............air up, drive home
01-02-2007, 08:15 PM
CF Senior Member
Steve,
What wheels are on the rears?
01-03-2007, 08:24 AM
Cruise-In V Veteran
NCM Ambassador
billiardcue
Steve,
Hey Bill,
Just 18 x 12 HRE 545s
01-24-2007, 02:42 PM
CF Senior Member
like to see those same pics in a aftermarket skinny besides CCW!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
