Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-20-2006, 03:22 PM   #1
FRCBobby
Supporting Vendor
FRCBobby's Avatar
Send a message via MSN to FRCBobby
Default ET Street vs ET Street Radial
Which of these tires would better suit my traction needs.
Will not be driving to the track on the tires.
Car still has stock rear including half shafts.
__________________
KYSpeed.com | FREE SHIPPING & HANDLING | PRICE MATCH | EMAIL
Kook's | American Racing Headers | Vararam | HallTech | Textralia | SPEC | McLeod | Raptor | Trick Flow | AFR | ECS
| FAST | APS | TTi | Procharger | RPM Transmission | Comp | DMH | HP Tuners | PFADT | SLP | STS
FRCBobby is offline   Reply With Quote
Old 09-20-2006, 04:11 PM   #2
YO-EL
CF Senior Member
YO-EL's Avatar
I looked at your signature & you're probably right on the bubble...
A basic rule of thumb is up to about 400-420 RWHP, drag radials can suffice, above that the slicks are a better choice..
YO-EL is online now   Reply With Quote
Old 09-20-2006, 06:58 PM   #3
JD434
CF Member
JD434's Avatar
My question is this:
Is there a difference between the M/T ET Street and the M/T Drag Slick?
I was wondering if they were the same tire but the ET Street had grooves in it.
JD434 is offline   Reply With Quote
Old 09-20-2006, 08:53 PM   #4
Face
CF Senior Member
Face's Avatar
Send a message via AIM to Face
There's less of a chance of wheelhop on e.t. streets.
Face is offline   Reply With Quote
Old 09-20-2006, 09:01 PM   #5
C3 Stroker
CF Senior Member
C3 Stroker's Avatar
The ET Streets and the Drag Slicks use the same compound; the Streets have the minor groove and slightly stiffer sidewall to make them DOT legal.
C3 Stroker is offline   Reply With Quote
Old 09-20-2006, 09:11 PM   #6
C3 Stroker
CF Senior Member
C3 Stroker's Avatar
Trying them both, I have had better results with the ET Street Radials.....I've been told the Street bias are quicker, but so far (at least for me) this has not been the case. The Radials use a stickier compound and hook easier. They also have less rolling resistance. (This is on a '69, running 11.6s in the 1/4.)
Old 09-21-2006, 01:22 AM   #7
REDGAR
CF Senior Member
Cruise-In II Veteran
Cruise-In VI Veteran
CI VI Drag Champ!
Drag Race Event Coordinator
REDGAR's Avatar
I forget who said it but they spoke to MT and MT said the bias play would be the better choice for the manual trans. I have both sets with the A4 and find the bias play a little more consistent.
Wheel hop is a big conern for the M6 and again, the bias with the softer walls tends to be better to proctect against wheel hope
REDGAR is offline   Reply With Quote
Old 10-27-2006, 11:26 PM   #8
LV Vette
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
LV Vette's Avatar
Send a message via AIM to LV Vette
I'm kind of searching for an answer on the radial/bias ply tires issue. How much of a problem is running MT ET streets (bias ply) with radials up front. Would tire pressure on the rears change anything? I am looking to reduce wheel hop problems.
Thanks,
Clayton from Las Vegas
LV Vette is offline   Reply With Quote
Old 10-28-2006, 12:05 AM   #9
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I don't think changing FRONT tires will do anything for wheel hop. Wheel hop is more of a traction/driver's launch technique/track prep issue. If you don't want to break you'd better do your best to avoid wheel hop.
Ron
__________________
09Z06Bone stock on DR's
10.750@128.19,1.563 60'@MIR,MD 3/25/11
Timeslip, 10.79Video
06Z06 M.S. Bone Stock
11.242@122.38, 1.688 60' @ Atco,NJ 11/17/06
Bone Stock on DR's
10.912@126.32,1.62 60' 12/5/08@Atco,NJ
Black 03ZO6
RPS clutch,Hurst,160* tstat, headers,Vararam, LS1 edit tuned, RPM trans & DTE brace all @ECS.
Best Pass: 11.21@122.30,1.58 60' 11/18/05 @ Atco,NJ. Slip
Best Street tire Pass: 11.67@119.3,1.711 60' 10/17/03@ Atco,NJ w/ a Vararam & Tune only
Dr.Ron is offline   Reply With Quote
Old 10-28-2006, 07:56 AM   #10
JerryL
CF Senior Member
Cruise-In III Veteran
JerryL's Avatar
Edgar is right, bias ply tires (ET Streets) are going to work better on a manual transmission car.
LV Vette - I've found that bias in the back and radials in front cause handling problems. Increasing rear tire pressure isn't goin to solve the problem. Radials in back with bias in the front are O-K on the track.
__________________
02 Z06
Cartek forged 427 (LS7): Callies crankshaft, Manley rods, Diamond pistons, ETP 240 heads, Jesel shaft rockers, NX direct port fogger, NX Maximizer, LSX Fast Intake, Kooks headers & X-pipe, Meziere water pump, Coan TH400 & converter with pro trans-brake installed by RPM, CCW drag package, Line-lock, Neverlift roll bar, American Super Car Challenge Serious Street Champion 2005 & 6
JerryL is offline   Reply With Quote
Reload this Page ET Street vs ET Street Radial
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
MT ET Street, Bias Vs Radial c5man99 Drag Racing 15 08-23-2005 12:40 AM
ET Street vs Drag radial for 380-450 RWHP Z06. Icevettez06 Performance Results 30 07-13-2004 11:59 PM
MT et streets vs MT drag radials robz C5 Tech 22 05-15-2004 05:15 PM
ET street: tire pressure VS 60' Phil97SVT Drag Racing 16 04-29-2004 02:45 PM
E.T. street vs. BFG drag radial life Face Drag Racing 19 08-22-2002 11:29 PM
et streets vs drag radials abraham Wheels & Tires 11 05-23-2002 09:03 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
