I was asked to post a technique for doing a burnout without a line-lock. Here it is:
Burnout Procedure Without a Line-lock
1) Put car in Competitive Driving mode (C5) or TC-Off (C6)
2) Drive around the water.
3) Back into the damp area, not the wet area. Back up enough to get 3/4 or more of the tire tread damp. Don't spin the tires in the water. You just want to get most of the tread with a sheen of water.
4) Roll forward to the leading edge of the damp area. Start the burnout there. Do NOT roll so far as to put the rear wheels onto the heavy sticky rubber/VHT prepped area.
5) The car should start and finish the burnout with no more that a foot or so of forward movement.
6) Put the tranny in 2d gear. This will enable the tires to heat faster, because they’ll spin at a higher indicated mph. Since the tires are damp, they spin quite easily in 2d.
7) Drop the clutch, feed the throttle and immediately lightly apply the brakes with your left foot. The brakes are helpful for keeping the rear-end from walking sideways.
8) Bring the rpm to about 5000 and hold it there until the tires smoke strongly and start to drag down the rpm. At that point, back out of the throttle and release the brakes. You'll roar forward. The tires are heated.
9) It is helpful if you adjust the driver’s outside mirror to view the left rear wheel/smoke.
10)
Warning, if you botch the burn-out, DON'T retry it with dry tires. Doing that will likely glaze the clutch...or…break an axle.
11) Practice will help get the synchronization of the foot movements.
You can practice in a level asphalt parking lot with water from a couple gallon jugs.Draw a couple lines with chalk to help establish an alignment guide. Pour out three or four gallons of water generally at the wheel points. Voila. You’ve got a pseudo water-box. An observer/spotter is a plus.
Don’t worry about brake wear. Four seconds on the brakes is like braking 60-10. You do that every time you drive the car.
Here is a link to a video of
Ranger's Burnout without a Line-lock Please right click save as......
In the vid I'm on DRs. Would have spun the stock tires just to first decent smoke.
Backed into the damp area just past the concrete stripe and then pulled forward to the leading edge of the damp area.
Play it slow-mo. I drop the clutch and hit the brakes. You can see the brake lights. I spun them to strong smoke; and when the rpm began to be drawn down...then backed out of the throttle and released the brakes. You can see the two marks in the surface where the tires spun. The whole process took four seconds.
Ranger
