Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Drag Racing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Drag Racing
Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events CF Timeslip database Sponsored by
Collector Car Nation
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2005, 12:38 PM   #1
asmokegars
CF Senior Member
St. Jude Donor '03-'06-'07-'08
asmokegars's Avatar
Default PA inspection - passed 5K exemption?
Anybody out there in PA to confirm this?
I just got my car through the PA emissions inspection today. ECS went with a Z06 cam in my old 382 to keep it mild enough to get through! Thanks guys.
Now I want replace my old heads with AFR 225s and a meatier bump stick which will put the car over 700RWHP and replace the 390s that are whining back to 342s. Some daily driver
I am assuming that as long as I put less than 5k miles on it I am exempt from the emissions test and only have to do the safety test.
Can I get some confirmations on this? Also, can I do it year after year. So lets say I drive 4K this year and I get an exemption for 2006. Then I drive it another 4000 in 06 can I get an exemption for 2007? Thanks!
asmokegars is offline   Reply With Quote
Old 04-09-2005, 12:59 PM   #2
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
Must.. have.. more... power
DOUG @ ECS is offline   Reply With Quote
Old 04-09-2005, 01:27 PM   #3
asmokegars
CF Senior Member
asmokegars's Avatar
Quote:
cocoa puffs! Doug - what a beautiful GREEN day!
Old 04-09-2005, 02:13 PM   #4
SmokeGray89
CF Senior Member
SmokeGray89's Avatar
Send a message via AIM to SmokeGray89
As long as you stay under 5000 miles each year you are exempt from the emission test that year. You still have to get an exempt sticker each year. It does not matter how many years as long as you stay under the 5000 miles between yearly inspections. I haven't had to go through the emissions test for the last 7 or 8 years.
SmokeGray89 is offline   Reply With Quote
Old 04-09-2005, 08:47 PM   #5
ralph
CF Senior Member
That is a good law.....heck if you're not driving over 5K a year, you can't be poluting too much. Makes sense.......which is unusual for an emissions law.
ralph is offline   Reply With Quote
Old 04-09-2005, 09:20 PM   #6
RichS
CF Senior Member
RichS's Avatar
For us in Luzerne County under 5000 miles they don't check anything but the normal safty items and you get a Exempt sticker.
__________________
96 GrandSport#857,Red Gut
Best ET w/396 & 6-speed 11.02 @126.57 w/1.60 60'
Best ET w/396 & 700r4 10.82 @124.87 w/1.48 60'
397 LT4,Morgantini racing heads,3:73 gears, DRM longtubes, Sepanek 700R4, Yank 3600, bla-bla...
2003 DarkShadowGray Ford Lightning 460rwhp/550rwtq 12.11@112.18 w/1.71 60'
2010 White Grandsport ECS blower,meth and ZR1 cam 680rwhp/638rwtq 10.89@131.88 so far...
RichS is offline   Reply With Quote
Old 04-10-2005, 02:09 AM   #7
SmokeGray89
CF Senior Member
Quote:
It doesn't matter where you live in the state, if you are under 5000 miles every year you get an exempt sticker. I'm in Philly and I've been exempt every year for the last 7 years.
Old 04-10-2005, 09:48 AM   #8
RichS
CF Senior Member
RichS's Avatar
They just started it last year for us.
__________________
Old 04-10-2005, 12:00 PM   #9
TA
CF Senior Member
TA's Avatar
The only thing I'll add is that I believe the car would still have to pass a visual check (ie: cats in place, EGR in place, etc).
TA is offline   Reply With Quote
Old 04-10-2005, 12:09 PM   #10
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
Quote:
I think you're right here. A friend of mine who researched it last year told me the same thing about the visual check.
'06 Quicksilver Z06 is offline   Reply With Quote
Old 04-10-2005, 01:01 PM   #11
asmokegars
CF Senior Member
asmokegars's Avatar
Thanks guys!!
Fresh inspection sticker and documentation of test with milage in hand.
OK ECS - time for the AFRs and the bigger bumpstick. Good comments about the visual - I'll keep that in mind.
Old 04-10-2005, 02:52 PM   #12
SmokeGray89
CF Senior Member
It depends on where you take it for inspection. As of right now, I was told that the state of PA doesn't require a visual check. The only time you may run into a problem is if the car is too loud. They may do a visual check then.
Old 04-11-2005, 08:17 AM   #13
85vet
CF Senior Member
Cruise-In V Veteran
85vet's Avatar
A visual is supposed to be required, but alot of the inspectors have no idea what the engine compartment should look like.
So with less than 5000 miles you should be good to go.
__________________
427 pump gas, TPIS Solid Roller700/701-AFR 220, Rossler700r4, 4,000 stall (Engine by CORKVETTE1), 3.45 gears
13.856 @ 100.311 (no stroker!)
12.434 @ 111.47 (LP219 cam) 383
11.227 @ 121.96 (Solid Roller & ported SR)383
11.033 @ 124.70 (Single Plane intake)383
10.967 @ 122.80 (E-Town)383
10.861 @ 123.60 383
10.88 @ 125.14 427
85vet is offline   Reply With Quote
Old 04-11-2005, 09:58 AM   #14
CYA-Vett
CF Senior Member
Send a message via AIM to CYA-Vett
Hi Alan, glad to see your beast coming into shape. When is the next rental?
My car always has less than 5,000 miles on it at inspection time.
You will have to pay $30 for an exempt sticker, they will still put it on the machine and also test yours gas cap, even thought you are exempt they need the readings for their records.
The actual inspection requires a visual check, you should have no problem finding a decent shop that will overlook the missing cats. Even though the car is exempt the inspection can fail without cats, makes no sense but thats the way it is. Been there, done that.
Dave
CYA-Vett is offline   Reply With Quote
Reload this Page PA inspection - passed 5K exemption?
Tags
5000, 5k, 60, afr, exemption, inspection, mile, miles, pa, pennsylvania, sticker, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
