Quote:
Hello again, folks. Some of you may remember I started a similar topic a while back, but now I'm ready to actually spray this sucker- it was a Maisto 96 red coupe that I'm trying to spray black rose to match my car. I want the paint on the model to have the depth of paint on a real car
I have the diecast stripped to bare metal. The plastic pieces appear to have the color molded in, though (they've been soaking in brake fluid overnight). I have automotive paint left over from when I had some work done on my 1:1.
For the questions:
-What primer do you guys use, for metal, and for plastic?
-I have a $10 Harbor Freight airbrush. What ratio should I dilute the paint?
-How many coats of paint, and how should I sand the paint between coats?
-What clear coat should I use, # of coats, and how do I sand between coats?
It probably seems like I'm taking this to a whole new level of obsession with the clear and all, but I have some neat plans for this car and some real tricks up my sleeve. I want the paint to be incredible, and match my 1:1. I can't wait to show you guys pics of the final project!
Thanks alot, guys!
Jared :flag
1. Go to Walmart and pick up a can of "Sandable" gray primer as you will need to put on a coat, sand smooth with 600, another coat sand smooth with 800, and then last coat sanding with 1000 grit.
Car needs to have no flaws and be very slick.
2. Get a better air brush. Cheap airbrush equals cheap operation. Either buy or borrow a good doulble action air brush. Use psi at 20 to 30 lbs.
I mix paint and thinner at 60/40 ratio but sometimes less depending on the paint characteristics.
3. Spray a coat of Testors Model paint in silver over car. Deeper and slicker
paint can be done with five coats if applied correctly.
4.Shoot first coat and let dry and harden for 5 to 7 days. Wet sand with 1000 grit. Second coat same way and sand also. Third coat same again as well.
On fourth coat mix color and clear about 60 / 40. Do not sand but wait a few days for coat to harden. Last coat mix color and clear this time 30/70.
Let dry for at least a week.
I then will either wet sand with 2000 grit paper to make item smooth as glass or use Menzerna Intensive Polish. Finish with some pinnacle paint conditioner
and then I like using Pinnacle Paste Glaz.
Car should have the color you wanted plus depth and be absolutely slick.
Here are some examples of a Porsche I built.
