Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Die Casts & Collectibles
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Die cast Models, 1:24 and 1:18 Scale, Corvette Memorabilia
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-15-2002, 11:17 AM   #1
DavesC5
CF Senior Member
DavesC5's Avatar
Send a message via AIM to DavesC5
Default How to remove wheels???
This may be a stupid question, but how do you remove the wheels from a 1/18 scale model...like an Ertl? I want to switch wheels between two Ertl models and I don't really want to break anything trying to get the wheels off the cars. Thanks in advance.
DavesC5 is offline   Reply With Quote
Old 08-15-2002, 06:20 PM   #2
7Vette
CF Senior Member
Default Re: How to remove wheels??? (David Gamage)
I turn the car over, and put a pair of needle-nose pliers behind the wheel, one "needle" on each side, and gently push outward. The wheel should just pop off. You can also use two screwdrivers, but I find the pliers easier to handle.
7Vette is online now   Reply With Quote
Old 08-17-2002, 09:46 AM   #3
Alchemist
CF Senior Member
NC Events Coordinator
Alchemist's Avatar
On some brands like UT...it's actually easier to swap the entire wheel/suspension assembly which requires removing the body, but it's no big deal. ;)
Alchemist is offline   Reply With Quote
Old 08-17-2002, 11:11 AM   #4
96LT4
CF Senior Member
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
96LT4's Avatar
Default Re: How to remove wheels??? (Alchemist)
Like Alchemist said, it is only 4 screws on the UT models, takes less than 2 minutes. :cheers:
96LT4 is offline   Reply With Quote
Old 08-20-2002, 02:23 PM   #5
DavesC5
CF Senior Member
DavesC5's Avatar
Thanks for the advice. That is exactly what I did and it was quite easy.
Reload this Page How to remove wheels???
Tags
corvette, models, removing, ut, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to remove center caps?? NDMIKE88 C5 General 9 03-04-2005 11:30 PM
Anyone know how to remove WHEEL SPEED SENSOR? nericreations C5 Tech 11 02-04-2004 11:34 AM
Does anyone know how to remove heat spots from rotors without resurfacing? EditMan C5 Tech 12 11-25-2002 07:02 AM
how to remove 40 years of grime? dropTopTx C1 & C2 Corvettes 22 02-24-2002 11:53 AM
Brake caliper leaking how to remove????? Bills79 C3 Tech/Performance 14 08-07-2001 02:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
