Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Die Casts & Collectibles
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Die cast Models, 1:24 and 1:18 Scale, Corvette Memorabilia
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2009, 06:48 PM   #1
Hawk312
CF Senior Member
Default 1/12 `67 Corvette L-88 Coupe.....yes, an L-88
I had this one under wraps for a little while, but I think I can finally share some progress. As many of you know, I have always stuck with the Tri-Power set up, but after researching the L-88`s and unique they are, I decided to give it a try. I`ll spare the background on these rare cars, since I am sure you guys already know the history.
The air cleaner set up was a real challenge, but I think I am finally satisfied with it. Basically, what you see is peice of kit plastic, cut and sanded, heated until soft and then bent/formed, putty and then sand, putty and then sand some more, then a bunch of coats of primer and black laquer. It took forever to get the contours convincing. I also found this foam at work that is very dense, and is very convincing for 1/12 scale foam.
I have alot of painting to do on the engine yet like hose and wire "lettering", and the usual text on belts.
The chassis has the usual chalk marks, and as you can see, whoever marked this one was on his first day apparently, as he specified 0 shims, and someone had to correct him and specified 2. Can`t decide if I am going to keep that on there on not...not sure if I like that.
I also have the interior started. It was really tricky removing the radio detail, but I have that finished and hopefully will have pics up shortly.
All in all I think this will be a very unusual build. I don`t know of any large scale coupe L-88`s in die cast or kit form, and in all my year of modeling (almost 30 now), I have never seen this kit converted to an L-88.
Let me know what you think.
Hawk312 is offline   Reply With Quote
Old 10-19-2009, 11:00 PM   #2
Rogue C6
CF Senior Member
Rogue C6's Avatar
That is very cool! I like it! I think the kitty does too.
Rogue C6 is offline   Reply With Quote
Old 10-24-2009, 11:25 AM   #3
JScott
CF Senior Member
JScott's Avatar
Very nice work as usual! The only large scale 67 L-88's I've seen are the Franklin Mint 1/12 67 convertibles. What color are you going to paint this car? Have you built any of the 1/8 monogram 65 Vettes?
__________________
Currently owned:
'72 Coupe, 20k orig mi, pewter silver/blk, NCRS Duntov award
'65 Coupe, 365hp, A/C, maroon/blk
JScott is offline   Reply With Quote
Old 10-24-2009, 03:03 PM   #4
Hawk312
CF Senior Member
Thanks guys!
Quote:
Im keeping the color under wraps for right now, but I will say it`s a very rare combination. I am going to post pics of the body once I get it polished out.
Haven`t built the 1/8 kit yet....they`re a little hard to come by. I always thought the proportions looked a little off on that one? I would like to try one someday though. I do have the `85 vette, as well as the IROC, Turbo Trans Am, and the `79 Trans Am kits in 1/8.
Old 10-24-2009, 03:07 PM   #5
Hawk312
CF Senior Member
Here are some pics of the chassis....just some touching up to do. I tried to add all the labels, chassis markings, etc. I also textured the fiberglass spare tire compartment a little bit which is a first for me. It looks pretty convincing in person.
Old 10-25-2009, 11:26 AM   #6
JScott
CF Senior Member
JScott's Avatar
I see that there is a photoetch detail kit on evilbay for the monogram 67 1/12 Corvette and 1/12 69 Z-28. Search under models & kits for "Detail Set RMX" to see all the photoetch sets they have for many models. Have you seen or used them on any of your models? I plan on building the 67 Vette this winter and was wondering if they are worth it.
__________________
Currently owned:
Old 10-25-2009, 06:36 PM   #7
7Vette
CF Senior Member
Years ago I made a set of 1/12 '69 Yenko Camaros and I used those photo-etch sets on them with good results. I've never used photo-etch details much, but those seemed to be very good quality and much better than using decals.
7Vette is online now   Reply With Quote
Old 10-31-2009, 01:58 PM   #8
Hawk312
CF Senior Member
Got the interior pretty much done on this. The radio has been correctly removed from the dash, which was a whole lot of fun, trying carefully to not damage the surrounding plastic. I must`ve sanded then primered about 5 times to get it perfect.
Old 10-31-2009, 11:19 PM   #9
yamahajo
CF Senior Member
Cruise-In 9-10-11 Veteran
Georgia Events Coordinator
St. Jude Donor '08-'09-'10
yamahajo's Avatar
Location: 'Cause my Caddy's fully loaded and it's aerodynamic
dang - that looks amazing!
yamahajo is offline   Reply With Quote
Old 11-03-2009, 07:47 AM   #10
corvette-pilot
CF Senior Member
corvette-pilot's Avatar
look forward to the rest of the project pics.
corvette-pilot is offline   Reply With Quote
Old 11-14-2009, 12:11 PM   #11
Hawk312
CF Senior Member
OK guys...I can finally post pics of the exterior. It looks as though this one will be making it to eBay after all, as I don`t have a buyer for this one now. I actually just finished building it, just trying to find a set of rallye wheels to put on it (I am going give the option of the turbine or the rallye wheels to whoever buys this one).
I have to first apologize for my camera, or my photography skills, whatever the case may be. In real life, the blue on the stinger is much more blue than in the pictures. For some reason, I cannot get the color to record correctly.
Anyway, I wanted to build the rarest combination possible, and I believe there was only one L-88 built in this color combination. I think this is definitely going to be a one-of-a-kind build.
Old 11-14-2009, 01:26 PM   #12
65convt
CF Senior Member
65convt's Avatar
As Always, AWESOME!!!!
65convt is offline   Reply With Quote
Old 11-14-2009, 01:36 PM   #13
BOB'S C6
CF Senior Member
BOB'S C6's Avatar
Quote:
She thinks it's PURR_FECT and so do I.
__________________
2008 Corvette Velocity Yellow ,Z51,NPP,Both Tops,Nav.436 HP.
Previous Corvettes -05 Millenium Yellow Coupe,85 Silver Coupe
Previous User Name "Silver 85"
BOB'S C6 is offline   Reply With Quote
Old 11-15-2009, 01:05 PM   #14
Hawk312
CF Senior Member
Thanks guys!!
This one is finished! Please see it here:
http://forums.corvetteforum.com/die-...post1572140447
Please let this thread sink. Thanks for everyone`s help!
Old 11-19-2009, 09:06 PM   #15
GEEBEE711
CF Senior Member
GEEBEE711's Avatar
GEEBEE711 is offline   Reply With Quote
Reload this Page 1/12 `67 Corvette L-88 Coupe.....yes, an L-88
Tags
112, 12, 1967, cars, corvette, franklin, l88, mint, model, monogram, pewter, photos, pictures, project, sale, scale
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
VANITY PLATE LIST of MEMBERS - UPDATED AC54ME C6 Corvette General Discussion 1935 12-28-2011 10:04 AM
VANITY PLATE LIST of MEMBERS - UPDATED AC54ME C5 General 1959 01-10-2011 12:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
