Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Die Casts & Collectibles
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Die cast Models, 1:24 and 1:18 Scale, Corvette Memorabilia
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-18-2009, 09:02 PM   #1
TR6speed
CF Senior Member
St. Jude Donor '11
TR6speed's Avatar
Default Help Changing/Switching Wheels
I have a C6 Z06 my Auto Art and a C5 by ERTL. and I wouls like to put the Z06 wheels on the C5. Can the wheels be removed and switched out?
TR6speed is offline   Reply With Quote
Old 10-19-2009, 11:43 AM   #2
nhisfan
CF Senior Member
nhisfan's Avatar
Definitely do-able - but to make life easy, why not track down an Ertl Z06 and just swap out entire the chassis?
Should be tons of them on 'that auction' site...
If for no other reason - the Auto Art deserves better than just being a donor...
good luck - geo
__________________
nhisfan is offline   Reply With Quote
Old 10-19-2009, 01:59 PM   #3
PostShawn
CF Senior Member
PostShawn's Avatar
It's definitely easier to keep within the same brand. I tried with three of the cheaper brands to get wheels from one onto one of the other two. The problem is the way the wheels mount is quite different. Some of the wheels I've seen have brakes in and part of the wheel and some have them separate. The mounting of these wheels to an axle like part and suspension varies very much too. I was going to have to custom make mountings for the wheels if I gone through with it. I changed my mind on the wheels I wanted so I didn't go further though.
PostShawn is online now   Reply With Quote
Old 10-19-2009, 11:03 PM   #4
Rogue C6
CF Senior Member
Rogue C6's Avatar
Quote:
Don't do it.
Rogue C6 is offline   Reply With Quote
Old 10-20-2009, 10:05 AM   #5
bullmarket
CF Senior Member
Support Corvetteforum!
bullmarket's Avatar
Autoart is much better quality and should be saved. I agree with the others...find another Ertl and swap out.
bullmarket is online now   Reply With Quote
Reload this Page Help Changing/Switching Wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
Opinions changing Z51 to a Z06 rear spring bamcoc5 C5 Tech 17 11-07-2003 01:04 AM
brake pad reccomendation for street and some track? BBQ Autocrossing & Roadracing 22 08-02-2003 08:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
