Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Die Casts & Collectibles
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Die cast Models, 1:24 and 1:18 Scale, Corvette Memorabilia
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2005, 06:16 PM   #1
indy300
CF Senior Member
indy300's Avatar
Default Decal placement on kits
I need your help.
I'm working on the CE Z06 kit by Revell. I painted the body "arctic blue metallic" by Model Master. I love that color!
I've never put decals on plastic model kits before. Do you put the decals on after you've painted the color and before you clear coat it? Or after the clear coat?
thanks in advance!
indy300 is offline   Reply With Quote
Old 03-03-2005, 08:17 PM   #2
69mako
CF Senior Member
69mako's Avatar
After you clear coat it..if you do it before, the clear will wrinkle the decals
69mako is offline   Reply With Quote
Old 03-03-2005, 08:33 PM   #3
7Vette
CF Senior Member
I always put the decals on the paint, and then clearcoat over both the paint and decals. That way both the paint and decals are protected. Allow your decals plenty of drying time, at least 24 hours, and you should have no problem. I've never had any decal problems this way. If you want to be sure, test a spare decal first. Apply it to a piece of spare plastic, let it dry, then clearcoat it.
I might also add that putting the decals under the clearcoat will help prevent cracking and peeling over time. The best thing to do with any primer/paint/decal/clearcoat combo is to test first.
7Vette is offline   Reply With Quote
Old 03-04-2005, 11:22 AM   #4
indy300
CF Senior Member
indy300's Avatar
I have two responses and two different answers... Any other suggestions? Thanks.
Old 03-04-2005, 11:40 AM   #5
69mako
CF Senior Member
69mako's Avatar
Quote:
Go with 7vette's answer..he does this more then I do
Reload this Page Decal placement on kits
Tags
c5, corvette, decal, kit, kits
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
