C3s for Sale/Wanted Private Classifieds: Used C3 Corvettes For Sale, Modified or Stock Corvettes, and Restored or Original Corvettes
Looking for 68 to 74 Project car.
Old 08-17-2014, 02:58 PM
74vette74
Cruising
74vette74's Avatar
Default Looking for 68 to 74 Project car.
Looking for any corvette between 68 and 74 to restore. Looking for a project car. Hopefully close to Newfoundland, Canada
Frame can be bad, I have a good frame.
74vette74 is offline
Old 08-17-2014, 04:16 PM
530planeman
530planeman's Avatar
pm me at 4wesbrenton@att.net I have a 68 project
Wes
530planeman is offline
Old 08-17-2014, 05:55 PM
Black_Magic
Black_Magic's Avatar
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
1969 Vette - 427/390HP 4 speed - Factory Air
LOTS & LOTS of new parts need finishing
Fresh engine (correct "ORIGINAL" engine)
New wiring, interior, suspension, paint, etc.
More pics & info ===>> 1969 Vette Project
George
Black_Magic is offline
Old 08-17-2014, 11:18 PM
74vette74
Cruising
74vette74's Avatar
Default email sent, looking forward to your reply
Wes
Old 08-18-2014, 06:20 PM
74vette74
Cruising
74vette74's Avatar
Note:
Looking for somewhere close to where I live in Newfoundland Canada. or other close by Canadian Provinces.
ty
Old 08-18-2014, 07:48 PM
530planeman
Note:
ty
ty
How much of a project and what is your budget ?
Old 08-31-2014, 09:01 PM
fisheson
fisheson's Avatar
Default c-3 project
Vin sequence denotes late November or early December 1967 car, was Lemans or International blue. One piece nose and inner fenders, long hood wiper delete, NO RUST NO CORROSION! super solid bird cage. Was western/desert car and has been stored the last 15 years. Will make a great resto rod or street car. Was in original blue automatic bbc with ac car. I am offering a couple different motor trans combinations. (1) stroked sbc 417cu #511 400 block offset ground crank, 5.7 small journal rods, large solid crane cam/brodix aluminum +.100 2.19 intake, 188 exhaust ported polished bowl matched heads and are empty, need rebuild... Complete ACCEL mini tps tunnel ram ported and polished injectors, fuel rails, complete engine wiring hookup for a c-4 corvette with cal map adjustments/or a complete new closed loop harness/system for installation in any car with ecm and distributor and jet coat headers... Art car 700 r4 no lock up trans and two torque converters (2500/3000), drive shaft included. Frame is complete in gloss imron and ready to be assembled with complete 3:55 rear end assembly rebuilt a-arms, front suspension is power steering/wheels and tires Cragar ss 15" wheel and tires. Core bumpers, front and rear, headlight assemblies, gas tank, black seats, black dash, some gauges and some harness, steering column, steering box, convertible top assembly are included, and are JUST SOME OF THE PARTS AVAILABLE. (2) A 454/427/396 bbc/4 speed combination is also available in this project. Car will leave with one or the other. Can put together a package for almost any need. Steel dolly body sits on now is not included but can supply a wooden substitute if needed. 603/673-0234, Milford, NH 03055 $7500. or for all the pieces less motor and trans: $5000. i also have for a combnation with this car is an UNSTAMPED FRONT PAD 3963512 4-bolt main BLOCK, high distributer tower[early production] large oil cooler return line over filter boss, with a set of #3919840 435hp l-71 heads completely rebuilt, never used very nice shape, ready to bolt on, please look at pics for dates,set of rods 3/8 or 7/16, with a usable 6223 crankshaft that will need to be turned to size, and a 4 speed trans[muncie or bw] i have more than a dozen of them and no, the m-22 are gone!, but probably have a 621 bellhousing and a clutch and shifter set too that i will include......Thanks. Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
fisheson is offline
Old 09-01-2014, 04:23 PM
RLDVLT1
RLDVLT1's Avatar
Default 1970 Corvette Stingray Project car available
I have a 1970 Stingray Corvette which was a factory 350 with 350 HP with a 4 speed. The car does not have the original motor but had it replaced a number of years ago with a GM LT1 crate motor.
The car has been sitting for about 20 years and needs a decent amount of work but the frame is solid and the fiberglass is also in very good condition.
Located in Michigan.
RLDVLT1 is offline
Old 09-07-2014, 08:48 PM
RLDVLT1
RLDVLT1's Avatar
Default 1970 Project Stingray for sale
RLDVLT1 is offline
Old 10-17-2014, 10:43 PM
74vette74
Cruising
74vette74's Avatar
Finally got one, 4600 KMs round trip to get it home. 1970, Can't wait to get started on a frame off custom restoration.
dustin zosky (10-19-2015)
Old 10-17-2014, 10:47 PM
74vette74
Cruising
74vette74's Avatar
Default Pics of new toy, let the project begin.
Old 10-17-2014, 11:31 PM
Priya
Priya's Avatar
Where did you find it?
Priya is offline
Old 10-18-2014, 01:00 AM
illenema
illenema's Avatar
Not bad purchase.
illenema is offline
Old 10-18-2014, 10:50 AM
74vette74
Cruising
74vette74's Avatar
Found it in Quebec
Old 10-18-2014, 07:39 PM
wolfrano02
wolfrano02's Avatar
Default 70 vette
How much are you asking for this baby?
wolfrano02 is offline
Old 10-19-2014, 04:21 PM
74vette74
Cruising
74vette74's Avatar
Its not for sale, I just bought it a few days ago. I updated the post that I found one.
Old 10-19-2014, 04:30 PM
Priya
Priya's Avatar
I think Wolfran was referring to the car posted by RLDVLT1.
Priya is offline
To Looking for 68 to 74 Project car.
Old 10-20-2014, 01:34 AM
wolfrano02
wolfrano02's Avatar
Default 70 vette project
Actuality I was talking about the one you bought few days ago the 70.
It looks a good car how much did you pay for it , if May I know.
I have a 74 but I would like to buy a 69 to 73 because I like the flat rear, I'm just curious about how much you pay for yours.
Old 10-21-2014, 05:24 PM
74vette74
Cruising
74vette74's Avatar
Cost me $5600 including the cost to go get it 4600 KMs round trip
thats Car, Gas, Meals, Tim Hortons, lol
Old 10-21-2014, 05:26 PM
74vette74
Cruising
74vette74's Avatar
I also have a 74 but always wanted a 70 (The same year I was born) They are the nicest looking of the C3s IMO.
So I keep an eye out for a 70 to come up for sale, saw this and jumped at the chance right away.
Quick Reply: Looking for 68 to 74 Project car.
