C3s for Sale/Wanted Private Classifieds: Used C3 Corvettes For Sale, Modified or Stock Corvettes, and Restored or Original Corvettes
69 Big block #'s matching
Old 06-08-2014, 12:36 PM
DarrylJ
8th Gear
DarrylJ's Avatar
Default 69 Big block #'s matching
69 Corvette -Coupe All original - Numbers match - Body has NEVER been hit. Original paint, shines beautiful but it is 45 years old with a few chips and nicks. This car has had a complete mechanical restoration. Including frame off rebuild of all original drive train. Stainless steel brakes and fuel lines. Complete new exhaust, fuel tank, cooling system. Restoration has less than 500 miles. Original carbs rebuilt by Chuck Smith. Engine rebuilt by High Performance Engines. Transmission and rear end rebuilt. N.O.S. GM rotors. Original rally wheels powder coated. Original 69 trim rings - not repos. Red Line Radial Tires. All new Bushings and Suspension - Ball joints - tie rods, and shocks. Frame and all suspension pieces painted with 2 coats black epoxy primer - topped by 2 coats black semi gloss urethane enamel. Interior is all original - except Al Knocks seat covers and carpets. This car has never been modified or raced in its life.
This is a Canadian Car, with GM documentation - Also has the original Gas Tank with Tank sticker. This is NOT a Trailer Queen - "Corvette's are meant to be driven". This car is ready to drive - and enjoy the Tri Power. However if you want a show car it has the potential. Bottom edge of rear corners are perfect, wheel well edges are good and clean inside and out. The engine has been completely rebuilt bottom and top end - it was bored and new pistons rods resided and x-rayed - original crank polished - all new valves - roller rockers - new push rods - new cam lifters - timing chain - gears - oil pump - Engine assembly has been balanced. New hyd Crane Cam.
$39,900.00 USD
It is a 400HP with a M21.
Happy to send more pictures if need be.
604-566-0067
Old 06-08-2014, 04:09 PM
pedec
pedec's Avatar
Can you post some pictures
Old 06-08-2014, 06:38 PM
62corvette
Support Corvetteforum!
62corvette's Avatar
I read it through twice, but maybe I missed it. Coupe or convertible?
Old 06-08-2014, 07:40 PM
DarrylJ
8th Gear
DarrylJ's Avatar
It is a Coupe - Thanks - I edited the post
Old 06-08-2014, 08:27 PM
gunnerja
gunnerja's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
did i miss the price?
Old 06-08-2014, 09:57 PM
vettebuyer6369
vettebuyer6369's Avatar
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,318 Likes on 2,767 Posts
Im pretty sure it was there earlier, it may have gotten lost with the edits-
Price required, please.
Old 06-09-2014, 12:59 PM
vettebuyer6369
Asking price provided by seller: $45,000.
Old 07-04-2014, 10:30 AM
Dicecal
Dicecal's Avatar
Car still available? Where are you located?
Old 07-11-2014, 02:53 PM
Rich Mickol
Rich Mickol's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Very Nice GLWS
Old 07-24-2014, 07:59 AM
CanadianVetster
CanadianVetster's Avatar
604 -area code is Vancouver BC I believe
Originally Posted by Rich Mickol
Very Nice GLWS
Old 08-21-2014, 05:11 PM
DarrylJ
8th Gear
DarrylJ's Avatar
Yes the car is still available. I have lowered the price as i just got a different one. Sorry for the delay but I have been off line for months.
The car is in Vancouver...Call me if you have any questions.
Old 08-28-2014, 08:12 PM
Scott from Akron
Cruising
Scott from Akron's Avatar
Absolutely beautiful color combo. Good luck in selling.
To 69 Big block #'s matching
Quick Reply: 69 Big block #'s matching
