1972 corvette convertable
1972 convertable $15,000.00
383 stroker, afr 190 heads, comp cams 270hr roller cam
Built 700R4 with 2300 stall midwest torque converter
3.55 rear gears.
Comes with hard top which will need some work.
soft top needs to be replaced(it is a little old)
interior is dyed black, and has some streaks.
Engine was built by a very reputable local speeds shop and transmission is strong. Very low miles on engine and transmission
3.55 rear gears.
1.Is it an A/C car?
2.Can you post some pictures of the engine bay and interior?
3.How is the frame and birdcage? Any pictures of those?
4.Is it original color interior and exterior? Could you post the trim tag inside the drivers door?
5.How much time on the engine rebuild? Was it dyno'ed??
6.How is the paint?
Moose
6.How is the paint?
Moose
1.Is it an A/C car?
6.How is the paint?
Moose
6.How is the paint?
Moose
2.) I will get some to you(there is someone else asking for them as well)
3.) The Frame and birdcage are fine as far as I know.. I have had the car for 20 years and it has rarely seen any rain
4.) I do not believe it is the original colors. I believe the original color of the interior was tan(saddle), and I'm not sure what the original exterior color was. I bought the car from the previous owners who restored the car.
5.) The engine was rebuilt probably 2 years ago, and maybe has 3000 miles on it (and that is probably a high estimate) I drive the car about every 6 wks for about 10 miles (which is one reason I'm getting rid of it.. My family takes up my time). I did not have it dyno'ed.. wish I had, but I blew past my budget at the time.
6.) The Paint is in ok condition. It does have some trash in it where it was not done as well as it should have been. There is some small bubbling on the back. It looks good at 10ft, but up close you can see blemishes.
Oh, and the brakes were replaced years ago with o-ring sleeved calipers.
Yes, it is still available. I have a couple of people who are interested.
Here are the pictures that have been requested. It's dark in my garage so they are not the best. Have to wait for a sunny day to get better ones.
A bump for a NICE Corvette
Nice Corvette, if you do not sell soon, bring it to the Jackson Corvette show and put a for sale sign on it. I think the Jackson show is in July?
Best of luck
Best of luck
72 vette
Would it b possible for u to meet at Memphis Int'l airport. How would the car do say on a 400 mile trip. PM me harrellbd@att.net if interested.
Thanks,
BDHarrell
Thanks,
BDHarrell
Looks like a good solid base for what could be a special car.. Any leaks?
Do the headlights and wiper door work properly? What is the paint code on the trim tag?
Thanks,
Moose
Thanks,
Moose
There is a very minor oil leak at the back of the engine. It has been that way since it was built. It is not the rear main seal so I'm not sure where it is coming from... the guy at the speed shop thinks he knows where it is coming from, and told me to bring it back.. but I never have since it is such a small leak.
Trim tag 417 946
Which after search shows Saddle Vinyl interior and Elkhart Green paint.
The headlights do work. The wiper door has worked since I had it except just recently it stopped. It is still free and I can move it up and down by hand. I need to look at it to see what needs to be fixed... hopefully it is a vacuum line off.
Trim tag 417 946
Trim tag 417 946
