1982 11k miles
1982 11k miles
Not sure if I can go thru with this
82, 11,5xx mile w/ mileage log. Very Orig. Have orig wheels/tires, blades, plugs & wires, headlights, belts (in boxes).Multiple correct orig air & oil filters. All orig Chev and NCRS docs w/ printable jpeg of orig title. 2003 Hershey Mclellan car-97.6%? I have owned since 2000. Pre inspect by Tony Avedesian. Stored in climate controlled garage w/ no UV rays. Body vs rubber bumper difference in paint shade noticeable in sun indicating orig paint. Couple judges thought maybe too nice, I wax well? Heater core, fuel pump & pwr antenna (have orig) rep'l.
Stunning example 34 yrs later. They made 567 Brite Met. Blue cars.
Ive personally seen 5 total.
Minor engine leaks, Shift shaft seal leaks good (easy fix), and intermittent bug w/pwr antenna (believe relay conn. issue).R134 conv w/r12 orig caps showing. High side Schrader valve leak, easy fix & re-chg. AC wk'd great. Xfire runs flawless.
Any of the above corrected by me (mstr tech) prior to sale, or adj $$ accordingly.
Havnt jacked up since 2013 but Minimal typical corrosion only exists.
Coolant, brake, trans been changed & yearly LOF.
$25k w/ 20' 1995 enclosed pace trailer, neg??
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Beautiful! Thanks for sharing the pics! I've never seen a '82 in that color. GLWS!
