C.e 1982 for sale
C.e 1982 for sale
[ATTACH][ATTACH][/ATTACH][/ATTACH]For sale is my 1982 C.E. Original with a few new parts. Purchased with 74,000 miles and currently 76,463. Driven on weekend only and for short periods, no rust but is showing signs of minor surface rust needs TLC to make it complete. In search for a C-6 and car needs new home indoors to preserve. Pros. new brakes, red caliper, rotors, lines, pads, master cyclinder, wheel bearings all from VBP. Light switch, blower motor, belts, dist. cap, plugs, air filter,wires, rad hoses, thermostat, valve covers seals, tranny fluid, filter, gasket. Shifter boot, tires, weatherstrip for doors, pillars and post from willcox. Sending unit, fuel filter. sunvisor support kit, dome light lens, rear script, hood lock catch,pop up spring, hood release cable clips, alternator, sway bar link, cushion set, spring rear, htr./ac cont. vac switch, htr/ac lens. Original carpet, Ravelco alarm, Paint has high gloss, Drives strong. Htr. works.
Cons: needs hatch weatherstrip,tee top weatherstrip, head lights delay in coming up but come down. Starts right up, but hesitates when accelerated but runs strong after warm up. Needs suspension tune up, dried out bushings. Needs door panels, seat covers. Minor spyder crack on the front lower bumper, no decals, door chips, all touched up. Washer pump doesnt shot water, no a/c comp. shows power but didnt get chance to address it. Oil leak from rear main seal. Asking 10,000. or make offer, I need to move car for a daily driver Vette.
Received 1,470 Likes
Cruise-In II Veteran
You might want to tell folks where the car is located.
