68 Covertible
68 Covertible
68 Convertible
509 bowtie block
Steel Crank
Crowder rods
JE pistons
Comp roller cam
GM Aluminum rectangle port heads
Manley severe duty valves
Crower stainless rockers
Performer rpm intake
Carb shop Holley
MSD
Functioning L88 air cleaner/hood
Custom 3" mandrel bent exhaust
Fluidampr
Polished BeCool radiator
Aluminum flywheel
Richmond 5spd
Ram clutch
Denny's nitrous ready drive shaft
Richmond 3:07 gears
Polished case with hardened gears from Toms axles
Toms steel cap with big bolts
Toms inner axles
HD Cover
Offset trailing arms
Toms outer axles
V&B 360lb spring
V&B camber rods
Stainless brake hose
Crossmember reinforcement kit
Poly bushings
Bumpers rechromed
Stainless polished
CP-200 15" rims
PW,PS,PB
Solid frame and birdcage
Admiral Blue paint (13 years old)
Interior shows ok but needs some work
Not a show car but still nice
9.5:1 comp runs on pump gas
Call for the details
719-660-5067
$25000 firm
509 bowtie block
Steel Crank
Crowder rods
JE pistons
Comp roller cam
Carb shop Holley
MSD
Fluidampr
Aluminum flywheel
Richmond 5spd
Ram clutch
Richmond 3:07 gears
Toms inner axles
HD Cover
Toms outer axles
V&B 360lb spring
V&B camber rods
Poly bushings
Bumpers rechromed
Stainless polished
CP-200 15" rims
PW,PS,PB
719-660-5067
$25000 firm
Mannnnnnnn if I wasnt stuck on deployment until June I would have already called!! Good luck with the sale
