C3 1978 silver anniversary L82 4 Speed 4 sale
Cruising
Sold
Corvette 1978 silver anniversary L82 4 Speed frame on restoration California car all of its life. Build specs, rebuilt 350 high compression pistons, Edelbrock high performance heads, Edelbrock intake manifold, Edelbrock 600 CFM carburetor, racing cam, high performance headers, new Magnaflow mufflers, new K&N air cleaner, 4 speed, New clutch, new tires, new rotors, new pads, new calipers, new power brake booster, new power brake master cylinder, new power steering control valve, new power steering pump, new AC compressor blows cold converted to new system, new shocks, new suspension parts front and rear spring, all new interior, power windows rebuilt, and new paint. My loss is your gain $15,500.00 OBO .
Cruising
CP from another post on the forum.
Smog
AB2683 states....
(1) Submission of proof that the motor vehicle is insured as a
collector motor vehicle, as shall be required by regulation of the
bureau.
(2) The motor vehicle is at least 35 model-years old.
(3) The motor vehicle complies with the exhaust emissions
standards for that motor vehicle's class and model-year as prescribed
by the department, and the motor vehicle passes a functional
inspection of the fuel cap and a visual inspection for liquid fuel
leaks.
It will pass per the new Cal regulation for 35 years or older insured as collectible. All it has to do is pass the sniff test and make sure there are no gas leaks..
Smog
AB2683 states....
bureau.
leaks.
Smog
AB2683 states....
bureau.
leaks.
Arnold got rid of this law...
Does my vehicle qualify for a smog exemption?
Smog inspections are required unless your vehicle is:
• Hybrid
• Gasoline powered 1975 year model or older
• Diesel powered 1997 year model and older or with a Gross Vehicle Weight rating (GVWR) of more than 14,000 lbs
• Electric
• Natural gas powered with a GVWR rating of more than 14,000 lbs.
• Motorcycle
• Trailer
http://www.dmv.ca.gov/vr/smogfaq.htm
Smog
AB2683 states....
bureau.
leaks.
Smog
AB2683 states....
bureau.
leaks.
DMV has no form to exempt it upon proof of Historical Insurance.....
I'm lost.....
HINT
If you get get, borrow by some means the original equipment to get it smogged once then determine which zip codes do not require biannual smog checks (rural areas) by going here...
http://smogcheck.ca.gov/pubwebquery/...ZipLookup.aspx
Once smogged
Drive to that rural location
Take out a PO Box
Inform the DMV of the address change for that vehicle
Once smogged
Take out a PO Box
Cruising
(g) For purposes of subdivision (a), any collector motor vehicle,
as defined in Section 259, is exempt from those portions of the test
required by subdivision (f) of Section 44012 of the Health and Safety
Code, if the collector motor vehicle meets all of the following
criteria:
bureau.
standards for that motor vehicle's class and model year as prescribed
leaks.
criteria:
bureau.
leaks.
Cruising
After he became govenator it was all down hill from there! What a piece of work a big dummy that never could learn to speak properly. The California public is even dumber than he is by electing him into office. Now we have the brown clown I think we should flush it.
