Stripped wheel stud
Old 12-05-2013, 11:40 PM
kingfish
kingfish's Avatar
Default Stripped wheel stud
What is the next step after one strips a wheel stud loose in the hub but still can't get the lug nut off or the stud out? Is the hub toast?
Old 12-06-2013, 12:48 AM
froggy47
froggy47's Avatar
Of course not, you may need to remove the hub to get it off or not. What year is the car?
rustyguns
rustyguns's Avatar
YEAH ! BUT 4 STUDS IS ALL YOU REALLY NEED NOT! LOL
Old 12-06-2013, 12:49 AM
rustyguns
rustyguns's Avatar
HAVE TO REMOVE HUB!
Old 12-06-2013, 01:33 AM
RedLS1GTO
RedLS1GTO's Avatar
Replace center cap. Post for sale ad.
Old 12-06-2013, 01:44 AM
RedLS1GTO
RedLS1GTO's Avatar
Not sure what wheels you have on the car but is there room to get a Dremel tool in there to cut it off?
Old 12-06-2013, 07:41 AM
kingfish
kingfish's Avatar
it's an '09 with z51
dremel cutting disk diameter is slightly too small to reach .
I need some way to get the wheel off since the free spinning stud will not let go of the cross threaded lug nut.
Old 12-06-2013, 07:44 AM
kingfish
kingfish's Avatar
wheels are stock gray 5 spokes
Old 12-06-2013, 09:10 AM
CHJ In Virginia
CHJ In Virginia's Avatar
About all you can do is remove the hub unless you are willing to trash the wheel. Remove hub and then grind the head of the stud off and drive out with a drift punch. Then carefully examine hub to determind if the knurls inside the hole are stripped, or if the stud was what stripped. Good Luck.
Old 12-06-2013, 01:09 PM
CGZO6
CGZO6's Avatar
Might be easier to disconnect the sway bar, brake line, ABS sensor wire and then remove upper and lower A arms (at frame/cradle), spindle, hub, rotor, caliper and wheel as an assembly.
I forgot about the steering linkage, gonna have to disconnect the tie rod as well (might be a bit*h with the wheel on).
Old 12-06-2013, 01:20 PM
froggy47
froggy47's Avatar
Take another lug nut and run it on up against the stuck one. This slave lug nut will be sitting on good threads (I assume).
Tack weld the nuts together.
Remove the nuts together.
Post back if this works, in theory I think it should.
Old 12-06-2013, 01:33 PM
yakisoba
yakisoba's Avatar
Think your best bet will be to grind off the head of the bad stud and punch it out as above, if there's no way to grab onto the nose of the stud (and there will not be if it's stock). Tough problem. Taking the tie rod end off and the sway bar should let the spindle swivel freely, which can buy you some more room. Just hard to get to the tie rod end.
Old 12-06-2013, 03:52 PM
mgarfias
mgarfias's Avatar
I'd probably take my plasma cutter and gouge the **** out of the stud/lug nut and pray i don't hurt the wheel. Work center out, and then use a chisel to finish the job
Old 12-06-2013, 05:07 PM
froggy47
froggy47's Avatar
That's brave but the temps on the hub might change the metallurgy (not in a good way)
Old 12-06-2013, 10:01 PM
kingfish
kingfish's Avatar
this is not sounding good
Old 12-07-2013, 01:10 AM
mgarfias
mgarfias's Avatar
Nah, the heat is localized. And would remain in the stud/lug nut. I wouldn't weld/cut on the flange that way but wouldn't worry about cutting the stud apart like that.
Old 12-07-2013, 11:28 AM
ZedO6
ZedO6's Avatar
Center punch the affected stud, and start drilling out the stud about 1/2" below the point where the lug nut is stuck.
Start with a small drill bit (1/4") and go progressively larger until you have cored out he stud to the point that it has about 1/8" remaining. Good sharp drills are a must. Once the stud is drilled out, take your 19 mm deep socket on a long extension and start rocking the socket/extension as far as it will go in opposite directions. Won't take much to snap it. This is far less work than removing the spindle and will not damage the wheel...Good luck
To Stripped wheel stud
Old 12-07-2013, 01:19 PM
Hi Volts Z06
Hi Volts Z06's Avatar
Before you get crazy with all these ideas (and there're several good ones) try removing all the other lug nuts and the have a friends pull back on the wheel while you try backing off the stripped lug nut. You might just be able to engage a good thread with the pressure of the wheel pressing againt the lug nut. Good luck.
Old 12-07-2013, 01:40 PM
ZedO6
ZedO6's Avatar
Absolutely! Do this first....
Old 12-07-2013, 02:05 PM
miss peel
miss peel's Avatar
The above method is the way I was able to remove my striped stud. I had to use a high tork impack with a commercial air compressor. My compressor at home would not do the trick. Took to a friend's work shop.
Quick Reply: Stripped wheel stud
