cheap lead for ballast
Old 11-26-2013, 12:12 AM
fatbillybob
fatbillybob's Avatar
Default cheap lead for ballast
Anyone know who sells the cheapest lead for ballast?
California tireshops no longer have lead wheel weights too many greenies in kali.
Shooting ranges are remelting their lead to make reload bullets.
Cracking open an old lead acid battery is just messy and nasty.
I need a 150 freaking pounds!
Thank You!
Old 11-26-2013, 12:16 AM
Jaymz
Jaymz's Avatar
Go to a local scrap yard. I bet they have some to sell.
Old 11-26-2013, 12:26 AM
froggy47
froggy47's Avatar
Scuba dive shop or exercise vest has lead weight pockets, but you pay retail.
http://www.missouribullet.com/detail...ary=&keywords=
Old 11-26-2013, 05:03 AM
Crepitus
Crepitus's Avatar
http://www.speedwaymotors.com/lead-b...ht-clamps.html
Old 11-26-2013, 10:08 AM
geerookie
geerookie's Avatar
E-Bay has been where I find the best deals. Shop for shipping options.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Also try searching under "ballast"
Old 11-26-2013, 10:56 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I buy from my local scrapyard. (Probably a law against that in Cali)
Old 11-26-2013, 11:32 AM
travisnd
travisnd's Avatar
There's a law against everything in Cali.
Old 11-26-2013, 11:52 AM
racer313g
racer313g's Avatar
We used to buy lead "pucks" from the local plumbing supply store. They were roughly the diameter of a hockey puck and weighed 5-10 pounds each. 150 pounds is quite a bit. Can you weld a steel box together (like brick sized) and fill it with lead shot?
Old 11-26-2013, 01:11 PM
eogel
eogel's Avatar
I bought mine from a maintenance guy for a local chain of gyms. They came off of replaced weight machines and already had holes in them to facilitate mounting. Very cheap.
Old 11-26-2013, 01:48 PM
c4cruiser
c4cruiser's Avatar
At our shop, we keep all of the old lead tire balancing weights and sell most of them to a scrap metal guy. We also keep a supply of them for the guys who want weights for fishing lines or for reloaders who shoot wadcutters or for black powder guys.
All wheel weights now (clip on or tape weights)are a steel mixture with no lead in them. It takes a lot more pieces to balance tires now.
Old 11-26-2013, 11:30 PM
1991Z07
1991Z07's Avatar
We had depleted uranium weights for the air force jets...
$hit was WAY heavier than lead...
Old 11-27-2013, 12:07 AM
froggy47
froggy47's Avatar
I think they use that in some ammo at the business end. Armor pierce stuff to drill a tank & such.
Yes?
Old 11-27-2013, 07:39 AM
chuntington101
chuntington101's Avatar
Yes?
a definite YES on that one. Google APFSDS for more info. used by MOST NATO nations although most are switching to Tungsten rounds (used to be used for practice) now as lets face it there aren't many tank on tank battles in war now.
Also most commercial aircraft use it in the tail to help with balancing.
Old 11-27-2013, 07:51 AM
rithsleeper
rithsleeper's Avatar
Post on craigslist and get plates for weight lifting. You can get 100lbs of assorted weights for around $20 here pretty easily.
Old 11-27-2013, 02:28 PM
fatbillybob
I question the safety of workout weights with a hole in the middle. Today they are usually steel which is physically much larger than lead. Second is how do you properly secure it in the car so that it is not a lethal projectile in the car? In my case I will be fully ballast with 350lbs of lead for my race class. A simple 45mph crash delta is about 50gs! So a smart person would build for at least that level of wreck. That means the 350lbs of ballast needs to be secured for 17,500lbs!!! I see people bolt in brake rotors to the sheetmetal floors and I question the brilliance of that.
Old 11-27-2013, 03:00 PM
Racingswh
Racingswh's Avatar
Received 1,074 Likes on 644 Posts
Just thinking safety. Could you sandwich whatever you use as ballast material (workout weights or whatever) inside the car between the floor and some type of plate so that is less likely to become dislodged? How is ballast traditionally secured? That's something I know nothing about and would like to learn more about it.
Old 11-27-2013, 03:04 PM
Olitho
Olitho's Avatar
I use two rotors weight about 37 lbs total to make weight. I have them bolted through the floor pan, but I go through the mounting bracket that holds the seat OEM belts. I figure that is strong enough to hold 37 lbs, but certainly not 350 lbs.
To cheap lead for ballast
Old 11-27-2013, 03:28 PM
RX-Ben
RX-Ben's Avatar
10g's is indicative of a mild crash. The last thing you want are weights/rotors taking flight in a crash. Use many bolts, spread the load.
Old 11-27-2013, 03:31 PM
fatbillybob
50gs is 1850lbs. Might be ok if your hardware is up to the task. Seat anchors designed for 250lb guy plus some margin of engineering safety. I have no clue. Need a real engineer not a chicken like me.
Old 11-27-2013, 05:07 PM
high9s
high9s's Avatar
I use Rotometals.com anything over $100 ships free, they are in California and very nice people to work with.
Quick Reply: cheap lead for ballast
