Front tire 315/30/18
I am thinking of going from a 295/30/18 to a 315/30/18 on my C6 Z06but was worried about rubbing.
Has anyone run that size tire up front with success?
Thanks for any info.
I know it's common for us in Stock class SCCA autocrosss to use that tire size on the stock wheel and there doesn't seem to be anyone complaining about rubbing.
Are you concerned with rubbing at full lock when turning, rubbing on the fender, or a combination of that?
I've run that size Hoosier R6 on 11" CCW wheels with minimal rubbing on the brake duct in full turn situations (paddock). With a 345 rear it gives very neutral handling.
305 fronts and 330 rears also provided neutral handling in my C6Z.
Jim
Jim
I ran that size Hoosier (A6) on my '09 Z06, with factory wheels and lowered on the stock trim height bolts. Just a touch of rubbing on the inner liner. This was for autocross only, and not driven on the street.
I'm running 10.5 C5ZO6 rims and 305's rear and 265 fronts and for the track they are fine, BUT you cannot run them on the street cause they will rub when turning lock to lock. On the track however they are great. My setup causes a little understeer but for me thats great since I'm still a novice HPDE2. Good Luck!
I chickened out and I am sticking with the 295's. My Forgelines are 11" up front and the offset would have had the tires sticking beyond the fender lip, and probably would have rubbed at full lock. I drive the car on the street so that wouldn't have worked too well.
For C6 Z06s, any effect on AH/TC/AB using 315/30/18s paired with 335/30/18 rears?
FRONTS -
Specification | Sidewall | Radius | Diameter | Circumference | Revs/Mile | Difference
275/35-18--------3.8in-------12.8in------25.6in----------80.4in------------788--------(0.0%)
295/30-18--------3.5in-------12.5in------25.0in----------78.4in------------808--------(-2.4%)
315/30-18--------3.7in-------12.7in------25.4in----------79.9in------------793--------(-0.5%)
REARS -
325/30-19--------3.8in-------13.3in------26.7in----------83.8in------------756--------(0.0%)
335/30-18--------4.0in-------13.0in------25.9in----------81.4in------------778--------(-2.9%)
FRONTS -
REARS -
FRONTS -
REARS -
FRONTS -
REARS -
The 295 will fit (and feel) better on a 11" rim anyway
Thank you. Unfortunately Toyo doesn't make a 345 for the rear.
However, do you mean 345/30/18 or 345/35/18? I ask because I'm having a similar conversation with tire selection where the 345/35 was recommended.
I found that to be very interesting as the tire size deltas are even larger than the setup in question.
A 345/35/18 is 3.1% taller than the stock sizes and the 315/30/18 is 0.5% shorter compared to the front. That should be a combined 3.6% delta between the front and rear tires compared to stock.
A 335/30/18 is 2.9% shorter. The fronts are 0.5% shorter. Since both are smaller, that should help offset the individual differences and the delta is closer at 2.4% between the front and rear tires compared to stock.
I'm not 100% sure if that's how the math works out for these systems, but it seems to me that keeping the differential between both the front and rear as close as possible would be ideal.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
The 295/30s and 335/30s are 30 revs apart, 2 away from stock, which should be OK.
