Pfadt c5 Z06 sway bar bushings
Old 10-18-2013, 04:06 PM
nassaubluecoupe
nassaubluecoupe's Avatar
Default Pfadt c5 Z06 sway bar bushings
I see where Pfadt has c5 z06 sway bar bushings for only $30. Would I be able to tell any difference in performance by putting these on?
Old 10-18-2013, 04:52 PM
sperkins
sperkins's Avatar
Probably not, but if anything it may make the car slightly more loose.
Some guys use bushing material as a fine tuning device, but I'm not that good.
Quick Reply: Pfadt c5 Z06 sway bar bushings
