2006 offset questions... knowing stock is +56 rear +79
will these be a terrible fit?
Size: 18x8.5 Offset: 46.0
Size: 19x10 Offset: 65.0
also should and can i go 10.5 rear without changing tires?
thanks for any and all help
This site is better: http://www.rimsntires.com/specs.jsp
You put your current wheel and tire size in along with your new wheel and tire size. It will then say how much farther in/out or bigger/smaller the new wheel/tire is.
The 245/40-18 on a 18x8.5 +46 will be .4" farther out toward the fenders. That will work.
The 285/35-19 on a 19x10 +65 will be .6" farther out toward the fenders. That will work.
I wouldn't recommend running a 305 in back with those wheels. It will rub or stick out too far as they would be .9" farther out.
