Okay folks, "hypothetically speaking" LOL, if you happen to roll your car through a SERIOUS oil puddle in the paddock are your tires ruined? Only one tire actually, a rear one, but is it a throw away now or can you simply wipe it down and be fine? Tire has one weekend on it.
Thanks in advance.
Just drive it off track for mile or so, then when you go back on track do a couple of easy laps. The tire rubber is not going to suck the oil deep into the tread like a sponge.
Should not be a problem. Drive first lap or two easy if it is a front. If it is a rear, do a short quick burst to spin em on pit out and you will be fine.
