Need help? C6-Z06 won't start
I have a highly modded 2006 C6-Z06. When I go to start it, the dash and radio screen go black except for the check engine light?? NO Noise, no start, no starter engaging. When I let out the clutch the dash relights up and other screen. If I push the start button again samething. The Battery is good, had it checked, could this be a bad starter??? and how can I check it?? Any other thoughts? Thanks, JD
If it does not crank, check the ground at the rear of the drivers side head. If it cranks but does not start, check the ground at the frame at the drivers side rear wheel well. That's the ground for the fuel pump. That's an easy starting place.
Good luck.
Good luck.
This was posted in Oct 2013!! Solution!! replaced starter!! All problems solved, car starts and runs fine. JD
Note: got starter from Advance Auto $90.00+
