F/S, forged LS1, road race or boost!
SOLD
Built for LSA Trans Am legal with stage 1 Dry Sump(DS not included)
Will make great road race engine or add boost!
Eagle crank and rods, ARP studs, Clevite bearings, 10.1 Mahle pistons,
stock bore and stroke
ASA cam, Comp valve springs, sodium filled valves, LS7 rockers and pushrods, ARP hardware
LS2 Intake, 90mm TB
Block, honed and deck measured
Stock heads(will make much more power if ported)
Melling oil pump, water pump with AN fitting, injectors, fuel rail, covers, coils, plugs
New Aluminum tubing and silicone 45’s included to angle radiator forward if desired.
6800 rev limit tuned ECU and harness, will spin to 7300 safely
438WHP on 91 Octane, used for 2 sprint races by Tom Sheehan
Just port the heads for a lot more HP or add boost!
$4900 OBO
I will be able to post pics of the engine on the stand with the pan off as soon as my back heals up a bit more, tweaked it last week on another project.
Thanks,
Rick
801-829-4997
LS2 Intake, 90mm TB
$4900 OBO
Thanks,
Rick
801-829-4997
