Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Inside edge front tire wear help needed
Old 09-07-2013, 11:41 AM
JerryC5
JerryC5's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Default Inside edge front tire wear help needed
After 24,000 miles my 2010 Vette convertible has excessive wear on the inside edges of the front tires. I am going to get new tires all around, and have a 4 wheel alignment.
Can someone give me the correct alignment specs, and recommendations on reduced camber to reduce the inside tread wear?
I will give them to the shop doing the tires and alignment.
Old 09-09-2013, 04:55 PM
zrracer
zrracer's Avatar
St. Jude Donor '11, '14
Shop will have them.
Old 09-16-2013, 08:57 PM
joenationwide
joenationwide's Avatar
Ask the alignment shop to run the minimum toe specs. This means closest to zero that is recommended. Too much toe is what causes premature tire wear. Negative camber just concentrates it to the insides.
Old 09-26-2013, 10:26 PM
StKnoWhere
StKnoWhere's Avatar
Alignment Guide
To Inside edge front tire wear help needed
Quick Reply: Inside edge front tire wear help needed
