Are TPMS needed on Track & AutoX wheels?
Old 08-10-2013, 07:36 PM
seattime
seattime's Avatar
Default Are TPMS needed on Track & AutoX wheels?
I am mounting BFG Rivals on Z06 Speedlines all around and not using TPMS's on these Track wheels and tires, will this work? I was told today that I need TPM's on all 4 wheels or the car will not run, is this true?
It is a 2001 C5
All help is appreciated,
John
Old 08-11-2013, 12:27 AM
KFehling
KFehling's Avatar
I am not sure about C5s but on C6s, you cannot activate track mode without TPMS. I would imagine C5s would operate similarly
Old 08-11-2013, 08:27 AM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Mine is a C5Z, no TPMS. However, the C6 guys with TPMS use a sealed pvc tube with sensors to fool the monitor into thinking the tire pressures are all OK. They just mount it in the cabin somewhere and can then adjust as they want without the computer screwing up the track day. Perhaps a C5 owner with TPMS can answer your concern. GL.
Old 08-11-2013, 08:48 AM
CHJ In Virginia
CHJ In Virginia's Avatar
I had a 2001 Coupe that I ran at numerous HPDE and AutoX events. Had a second set of wheels without TPMS and just swapped them out before the event. Car ran fine in comp mode or with the nannys turned off completely. The DIC showed a low perssure message until the street wheels were installed and the car could read the sensors. Go and have fun and don't worry about the sensors.
Old 08-11-2013, 11:09 AM
mountainbiker2
mountainbiker2's Avatar
No need for sensors. Just tap "reset" if anything comes up on the dash. That way you can read water temp. etc.
Steve A.
Old 08-11-2013, 12:56 PM
trapp
trapp's Avatar
Not needed BUT very useful to monitor tire temps on track... I used to determine what tire pressures I needed on track...
To Are TPMS needed on Track & AutoX wheels?
Quick Reply: Are TPMS needed on Track & AutoX wheels?
