Need shortcut to R&R P/S pump
Old 08-05-2013, 06:18 PM
froggy47
froggy47's Avatar
Default Need shortcut to R&R P/S pump - video added
There is supposed to be a way to do it by cutting up or drilling the stock pully (destroy it) in order to get to the bolts.
I know the alt comes off to give room.
The FSM says to remove the abs block. I'd like to leave that alone if I can help it.
Going back using a skeleton pully from Turn One.
Anyone who has actually done the pully destruction way?
How, what tools?
Thanks.
Old 08-05-2013, 11:32 PM
Paul Schmidt
Paul Schmidt's Avatar
How, what tools?
Thanks.
Hammer
Old 08-05-2013, 11:58 PM
froggy47
froggy47's Avatar
Originally Posted by Doug P
Hammer
Is the pully plastic?
Old 08-06-2013, 12:17 AM
taken19
Track Junky
taken19's Avatar
Yes, C5 pulley is plastic. You don't need to remove the ABS block... Maybe remove mounting bracket bolts at best. There's a way to cut the reservoir bracket to make future R&R easier. A search will give you pics on how to make your life easier.
Old 08-06-2013, 12:01 PM
mgarfias
mgarfias's Avatar
I smacked mine with a hammer to crack it, then used water pump pliers to rip it to shreds.
Old 08-06-2013, 12:58 PM
froggy47
froggy47's Avatar
Thanks guys, if anyone has a link to these alternates, please post.
I'll shoot a video when I install the new one.
Old 08-06-2013, 01:01 PM
sperkins
sperkins's Avatar
No need to destroy the pulley unless you just want to.
Old 08-06-2013, 01:18 PM
froggy47
froggy47's Avatar
I can't get a pully puller in the space between the abs & the pully.
The FSM says remove the abs & that seems to be a really complicated & unnecessary step.
Threading all those metal brake line fittings into the alum block & not crossthreading one does not look like fun, plus then I have to bleed it all.
Is there a puller that fits in tight places?
Please explain your post.
Old 08-06-2013, 03:43 PM
froggy47
froggy47's Avatar
I found a thread that details how to get the pump out by leaving it on the bracket & take the bracket out.
Maybe that's what sperkins means.
Old 08-06-2013, 04:48 PM
fcarga
fcarga's Avatar
And what thread would that be?
Old 08-06-2013, 05:03 PM
geerookie
geerookie's Avatar
You can remove the bracket without removing the pulley but you need to use a 15mm box end or open end wrench to work the bolt(s) behind the pulley out. It is slow and a pain in the butt, but it can be done.
If you are replacing the pulley I would just break it and use the new Turn One pulley.
I would just put a wrench or big pliers on it and snap it that way as opposed to hitting it with a hammer. I imagine that would be less stress to the shaft and bearing.
Old 08-06-2013, 05:17 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Easy way to get rid of stock plastic pulley is to use a large screwdriver. Wedge it between the pulley and mounting bracket and push. It will snap off fairly easily. Mine broke in half and then I rotated what's left and did it again. Makes getting to mounting bolts very easy. DO NOT move or remove the ABS unit it is not necessary. The turn one pulley has slots and you can tighten mounting bolts with pulley in place.
Be sure to flush out the entire system before starting new pump. DO NOT try to flush out by starting engine, you can not keep fluid in the reservoir fast enough to keep up ! Once you have it all back together, leave the fluid return hose loose and place in a bucket. With car up on jack stands, cycle the steering full left lock to full right lock and repeat 7-8 times or until fluid from hose comes out crystal clear. Reattach hose, fill and you are GTG.
Old 08-06-2013, 05:58 PM
froggy47
froggy47's Avatar
So you are saying that cycle the steering with engine OFF will be the flushing procedure? Just keep topping off the resevoir?
Fluid is pretty good now, I have been doing the suction refill on the resevoir every event (probably overkill0>
Old 08-06-2013, 07:31 PM
sperkins
sperkins's Avatar
Exactly, but if you plan on a T1 pump/pulley, I'd just do as Geerookie suggests..
Old 08-06-2013, 08:08 PM
froggy47
froggy47's Avatar
Old 08-06-2013, 09:28 PM
moespeeds
moespeeds's Avatar
I drilled a hole in mine, about 5/8" and you can get in there to remove the bolts. It's plastic so there's nothing to it. I would remove the EBCM, it's just 3 pinch bolts and it will be out of your way. It's tight working around it.
Old 08-07-2013, 05:48 PM
CHJ In Virginia
Absolutely. Cycling the rack via the wheel movement will move fluid through the system. It will take 7-8 complete lock to lock cycles to totally flush everything out. About a quart and 1/4 to 1/2 of fluid will be required. Best to do job with a friend to keep reservoir full, it will empty quickly.
Even if your fluid looks good, do a complete flush anyway. Do you want to risk any nasty particulates that might be somewhere in the system screwing up your new pump. Fluid is cheap.
To Need shortcut to R&R P/S pump
Old 08-07-2013, 08:30 PM
froggy47
froggy47's Avatar
OK, I am nothing if not serious about clean fluids.
Old 08-09-2013, 10:26 PM
moespeeds
moespeeds's Avatar
Will this method flush a dry system or does it need a prime? Got a new rack and pump in, trying right now but can't seem to get any fluid flowing.
Old 08-09-2013, 10:40 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
the shortest pulley remover I've found is the one Oreilly's sells/loans for the GM PS pulley, 67010 I believe is the number. It's a lot shorter than most of them
Quick Reply: Need shortcut to R&R P/S pump
