I damaged my engine
I damaged my engine
I was running hard on Watkins glen in open track and silly me didnt have that extra quart of oil in the engine to protect it from the steep turns, elevation changes etc.. I think the engine was starved for oil in some turns because I started to lose power. I pitted and checked the car and now it vibrates alot, knocks and makes sleigh noises. it burns oil, and idles like I have a cam in it when it is stock..
I was able to drive it home but the engine is straining and going brrrrr
everytime I hit the go pedal. 2nd feels like 3rd, 3rd gear feels like 4th and 5th gear feels like six in terms of acceleration. I am going to send it to vette doctors and see whats wrong.. could anyone here give me an idea of whats wrong? Is the engine salvagable? or is it cheaper to just replace it? It was a remanufactured LS1 under warranty, but Im afraid that it might not be covered.
also Im having tranny problems, mainly shifter problems some times when Im heel toeing down from 4th to 3rd the shifter doesnt go into 3rd... it is extremely frustrating when you are doing 140 and you are braking and down shifting and you never know if the gear shift is going to cooperate with you or not.. Im thinking of changing my stock C5 shifter because Im sick of fighting with it. could it be an overheating issue? are the C6 Z06 shifters better? thx
Not sure about your engine noise (but it doesn't sound good). As far as your shifting goes- I'm willing to bet you put in a new clutch recently. If so- try bleeding it. If that doesn't work- you may have to go to the Tick master cylinder which is adjustable. I thought everything you were speaking about (in terms of shifting) was the result of overheating (put in a cooler), shifter (installed the MGW) and still had the problem. I finally did my homework and realized what I needed to do.
In addition burning oil can come from two places: oil blowby and valve seals. Typically you can diagnos blowby if the oil burning or black smoke comes out the exhaust under power / throttle. Vavle seal cracks can often be seen during startup and engine decel while driving.
St. Jude Donor '05-'08
what year is your car? stock tires or race?
Shifting could be bent forks or clutch so changing shifter will not work. I do recommend going with a MGW shifter. I am sure you will like it.
http://www.mgwltd.com/corvette_short..._shifter.shtml
Received 8,919 Likes
Changing shifters isn't going to improve the shift from 4th to 3rd. There is some other issue. Remember all of the shifters available whether GM or aftermarket are pretty much the same. A long rod that is inserted in a circular hole with the bottom end of the rod going into the shift rod on the transmission. Very hard to blame the shifter when all it does is move the shift rod back and forth.
Bill
You run the codes? Do that before you tear anything apart. Could be something simple like a bad coil. Next I'd pull the manifold and look at the valvetrain. Easy to do and you'd be able to see if you broke a spring. Also get your oil analyzed to see what's floating around in it.
You spun a bearing. Your motor is basically trashed. It will run for a while, but eventually you'll throw a rod or seized rod on the crank. I bet the motor is loaded with metal particles.
Thx for all the replies
I will chk clutch and vette drs will let me know whats up
Its under warranty so if the engine is toast ill get another engine
Shifting might b an over heating issue because it seems to happen after a half hr on trk
I chked my video
With all my cursing! Lol
I chked my video
If the clutch is a metallic disc as opposed to organic- they tend to expand with heat so the problem gets worse as the car gets hotter. What clutch are you running in that car?
I chked my video
I chked my video
I recently changed my clutch fluid.. tranny is due for a flush, I will do that as well..
and the main reason I want to change my shifter is for a shorter throw..
But I dont like really tightly spaced shifters because I drove a corvette with one and almost shifted from 5th to 2nd when I ment to shift into 4th..
Maybe I would get used to it but it poses a big risk since I drive it on the street too occasionally, and drive it to and from the track.
I like the stock shifter, when its cooperating.. But it does have a longer throw than the C6 Z06 shifter.. we will see, I just want the car back in business so I can go back to the track!!
Well the engine was checked, #5 cylinder is low in compression,so that ones toast... but the rest of the cylinders are good.. I dont know if this engine will be fixed or it will be replaced.. we will see.. i have those two options.. Im hoping it is replaced..
