Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Widest tire?
Old 07-25-2013, 01:41 PM
czarredd
czarredd's Avatar
Default Widest tire?
Vette is currently running 275 40 17 all around but I wanted to know if I could run a 315 35 17 on the back for a wider stance. Will the stock wheel accommodate that rear tire size? Thanks
Old 07-25-2013, 06:25 PM
C4vettrn
C4vettrn's Avatar
What wheel? If it's a 17x9.5 then NO. The biggest you can go is 285 maybe a 295 but probably not safely. tire racks website will tell you what the rim spread in inches is for each tire, in the specs section.
Old 07-25-2013, 06:55 PM
czarredd
czarredd's Avatar
There the stock wheels.....is the stock size 17x9.5? Thx
Old 07-25-2013, 07:20 PM
czarredd
czarredd's Avatar
So yes....they are 17x9.5......will a 245-45-17 work up front then?
Old 07-28-2013, 07:20 PM
C4vettrn
C4vettrn's Avatar
Go to tire rack website and type in the tires you want and it will give you the rim sizes allowed/recommended in the specs section.
Old 07-29-2013, 12:35 PM
czarredd
czarredd's Avatar
Will some 18x8.5 / 19x10 wheels from a C6 fit my 88 C4?
To Widest tire?
Quick Reply: Widest tire?
