Aftermarket Wheels, Lug Nuts & Longer Wheel Studs
I'm in the process of figuring sorting out 18" wheels up front (make more room for my Wilwoods and maybe make the jump to 14" rotors next replacement).
So, I'm looking at TSW Nurburgring wheels, which everybody tries to sell with the keyed lug nuts. Do I have to buy them in order to use these wheels? I'd be fine reusing my stockers if I can and when I replace the hubs (or fab my spindle ducts) I'll upgrade the wheel studs to a set of longer ARP studs, which I'm thinking might be too long to use those lug nuts.
Anybody know for sure what works?
Yes, normal sockets fit fine, and there's just barely enough room to use some impact sockets.
I assume you are going to track/autox.
Some/most sanctioning bodies will require a tech inspection. If you have (stock) closed end lug nuts, they may fail you or may require that you remove a nut to check that you have sufficient thread engagement.
Some tech inspectors are pretty **** in my experience, looking for any little thing to make you "jump thru a hoop" to get the car on track.
The ones who have been doing it longer, tend to have more common sense to use.
Open lug nuts eliminate this issue.
Our association's autocross rules for lugnuts and studs require a minimum of 9 turns of the lugnut before tightening. For OEM wheels and studs, that works.
I'm not familiar with the specific wheel, but I would make sure that if you are using stock lugnuts, the wheel uses a lugnut with a 60 degree conical tapered seat (stock GM).
you don't need an "impact" socket for your wheels, shouldn't be torquing them with an impact guy anyway (just spin them down lightly). I use a thin-walled 1/2" socket, fits most any wheel, not an actual impact socket
