Installing Quartermaster Vdrive 5.5 need torque specs
Old 07-20-2013, 03:15 PM
moespeeds
moespeeds's Avatar
Default Installing Quartermaster Vdrive 5.5 need torque specs
Just about to bolt up my quartermaster V Drive 5.5" clutch and realized I don't have any torque specs. Need specs on the ARP bolts that go through the clutch mounting plate, though the flywheel, and into the crank snout. Also need specs on the long bolts that go through the clutch body to hold it all together.
Any help is appreciated,
Old 07-20-2013, 07:34 PM
geerookie
geerookie's Avatar
Flywheel is 3 passes.
15, 37, 74 ft/lbs
The bolts that hold the clutch I couldn't find a torque spec when I put mine together so I just did about 30 ft/lbs and I used nord-locks.
Last time I had it apart after about 8 weekends of running all was good.
Old 07-20-2013, 07:41 PM
moespeeds
moespeeds's Avatar
Where did you get the 74 ft/lb number? I looked it up and found a few references for arp flywheel bolts at 55 ft/lbs. Btw, clutch body is 20 ft/lbs as per qm's website. I torqued mine to 55 wonder if I should pull it apart...
Old 07-20-2013, 10:33 PM
geerookie
geerookie's Avatar
74 is from the GM manual.
To Installing Quartermaster Vdrive 5.5 need torque specs
Quick Reply: Installing Quartermaster Vdrive 5.5 need torque specs
