BBK tool question
Old 07-07-2013, 10:41 PM
Charley Hoyt
Charley Hoyt's Avatar
Default BBK tool question
What tool do you use to spread the pads on BBKs? On my stock brakes I used a big C clamp and a screw type compression tool. However, with my new Stoptech brakes these methods won't work. I have seen people using tols to spread all six pistons simultaneously but I don't know where to pick one up...
Thanks for the help,
Charley
Old 07-07-2013, 11:05 PM
JerryTX
JerryTX's Avatar
I found success and recycled an old drum brake adjustment tool like this that was in my toolbox:
That an one of the worn out brake pads and I'm able to compress the pistons fully on the inside and outside of my old Wilwood SL6 and my Stoptech ST60 calipers.
Old 07-08-2013, 01:30 AM
Last C5
Last C5's Avatar
I ground the last of the pad material off an old set of pads and use the remaining backing plates and a conventional paddle spreader. Works great!
Old 07-08-2013, 07:57 AM
sebdavid
sebdavid's Avatar
Elbow grease and ratchet handles as well as the old pad. It's a bit of a pain, especially when everything's hot.
Old 07-08-2013, 09:14 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Here is a tool that I found that works like a champ ! Just slide tool in the caliper and turn the handle. It expands and pushes the pistons back on both sides at once. A bit pricey at $45 but it works and easily !
http://www.zdmak.com/wbstore/main.as...K-BRK-J&CTMP=1
Old 07-08-2013, 09:19 AM
Scooter70
Scooter70's Avatar
I use this for stock calipers and it works great.
OTC 7034 Disc Brake Pad Spreader : Amazon.com : Automotive OTC 7034 Disc Brake Pad Spreader : Amazon.com : Automotive
Old 07-08-2013, 09:38 AM
sebdavid
sebdavid's Avatar
Looks like this would work for 4-pot calipers a bit more quickly, but perhaps with less ultimate force than what CHJ suggested:
Lisle 29100 Quick Quad Pad Spreader : Amazon.com : Automotive Lisle 29100 Quick Quad Pad Spreader : Amazon.com : Automotive
Old 07-08-2013, 10:44 AM
Bad Karma
Bad Karma's Avatar
I just did it with a couple of c clamps and. Small pieces of wood to protect the caliper. I want something easier myself. I might make sized just for my Wilwoods. If I need to change at the track that's not the quickest method.
Old 07-08-2013, 10:20 PM
Charley Hoyt
Thanks for all of the help. Now I have some options to consider.
Charley
Old 07-09-2013, 12:07 AM
kmagvette
kmagvette's Avatar
also available on ebay...tool is awesome for 4+ piston calipers
To BBK tool question
Quick Reply: BBK tool question
