c5 z06 nt-01 camber
Old 07-04-2013, 02:23 PM
Sebring27
Sebring27's Avatar
Default c5 z06 nt-01 camber
Hi
I am running 315/30/18 and 275/40/17 nt01
Presently stock camber alignment. I am getting50% more wear on outside of front tires. Any advice on alignment /camber would be appreciated. I drive to the trackon the nt01's (150 miles). Track, Chuckwalla, ca
Thanks!
Old 07-04-2013, 04:48 PM
sleeperstyle
sleeperstyle's Avatar
you need more negative camber, from what i have read -1.5 to -2.5 degrees in the front on a softer tire like the nto1. search is your friend. there are a few helpful stickies at the top of this section, which will explain it.
Old 07-05-2013, 10:51 PM
stevensa
stevensa's Avatar
I run -1.7 front -1.1 rear with 275 square nt01. My tire temps are nice and even across the face at about 200 degrees. This is with Pfadt poly bushings and JOC stage one.
Old 07-06-2013, 12:29 AM
Sebring27
Sebring27's Avatar
Many thanks!
To c5 z06 nt-01 camber
Quick Reply: c5 z06 nt-01 camber
