Fitting Ecklers nose - Poor quality.
Old 05-03-2013, 08:22 AM
sperkins
sperkins's Avatar
Default Fitting Ecklers nose - Poor quality.
Many complaints about my experience with Ecklers and the quality of the product, but I'll try to stay focused on this one issue.
How the hell am I supposed to get around this?
They obviously took it out of the mold before it fully cured.
Old 05-03-2013, 09:45 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I think Jody had similar problems. They steal another companies design, they don't even have the decency to make it right!
I guess you will need to "shim" it with something....maybe balsa or another lightweight wood, styrofoam, etc????
How does it fit around the lights, hood etc??? I've heard that's not great either
Old 05-03-2013, 09:50 AM
Falcon
Falcon's Avatar
Yep, that looks like the ones I've gotten from them.
We cut the notches off of the splitter and using spacers, we bolt the splitter to the nose and pull it down.
Old 05-03-2013, 09:52 AM
travisnd
travisnd's Avatar
Wallyman and Oyishdog had that bumper and I don't believe they had fittment issues like that. Stinks that you painted before test fitting!
Old 05-03-2013, 10:06 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Can't you heat it and bend it over time - I thought Beretta had an issue with a hood a while back and was able to get the corners to bend down after using some heat and some weights?
After doing a couple ACP/Eklers style noses and then trying out the Blackdog piece I have to say how much easier the Blackdog piece was to work with. I think my last install took over 10 hours less time using the Blackdog nose. Also the undertray and splitter are one piece (which you can make adjustable). The ACP/Eklers style nose you are pretty well stuck at whatever angle things end up at.
I know they Blackdog nose is expensive but IMO it is so worth it. If I need to get access to the underside of the nose of front of the radiator I undo a handful of bolts that close the gap between the bumper cover and splitter then 4 mounting bolts - splitter drops down and I have access. I would've never wanted to take apart the ACP style set-up.
There is defiantly something to be said for ease of use.
Old 05-03-2013, 10:28 AM
Wasserott
Wasserott's Avatar
Agree with what others have said. But let me correct something too, this is not an Ecklers/ACP product. It's an ACP product that was poorly replicated (stolen might be a strong term).
The heating idea is a great one that i would try first.
Old 05-03-2013, 10:44 AM
sperkins
sperkins's Avatar
Got any pics? If you use spacers, how did you not have huge gaps when you were done?
Old 05-03-2013, 11:12 AM
Falcon
Falcon's Avatar
Check your email.
Old 05-03-2013, 12:15 PM
96CollectorSport
That's why I said ACP/Ecklers style I was not trying to say that the Ecklers and ACP products are one in the same - just that it is similar in design.
Hope you get it sorted out Scott.
Old 05-03-2013, 01:04 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I would tell them to eat it damn thing that is a disgrace!
Old 05-03-2013, 02:04 PM
BERETTA
BERETTA's Avatar
Scott, I am sorry that sucks.
I had no fitment issues between the front fascia and the splitter, but I got everything from Kerry at ACP. The holes for the splitter were molded into the fascia.
A heat gun does work pretty good, maybe you could go ahead and drill some of the holes to mount the splitter to the fascia and use some threaded rod and ease the two pieces together a little at a time as you heat the fascia up?
Old 05-03-2013, 02:28 PM
travisnd
travisnd's Avatar
Old 05-03-2013, 03:22 PM
rfn026
rfn026's Avatar
So they ripped off ACP and then couldn't even make a decent copy. I just love it. I think Eckler's has been through a half dozen owners in the last decade. they've been in trouble for a while now. Things don't seem to be getting any better over there.
Richard Newton
Old 05-03-2013, 03:47 PM
Z06cool
Z06cool's Avatar
Mine wasn't perfect either but nothing that bad. You can still see a small gap.
Old 05-03-2013, 05:09 PM
Falcon
Falcon's Avatar
Scott, here is a photo that goes with the one I emailed you. This one shows the the gap filled in around the spacers.
There's a good bit of flexibility in the nose as far as pulling it down to the splitter.
Old 05-03-2013, 06:17 PM
John Shiels
ACP stuff fits like a glove but not on OJ!
Old 05-04-2013, 02:22 AM
sperkins
sperkins's Avatar
Thanks Jody. For your email too.
I spent a few hours on it tonight and I came up with a couple of ideas.
Not sure how much time I'll have to mess with it this weekend, but I hope to have an update in a couple of days.
To Fitting Ecklers nose - Poor quality.
Old 05-04-2013, 03:51 PM
davidfarmer
bolt it solid with washers, tape the front with painters tape, then fill the rear with spray foam!!!
Old 05-04-2013, 04:40 PM
Falcon
Falcon's Avatar
Yep, that'd work.
Heck of a good idea!
Old 05-05-2013, 01:50 PM
sperkins
sperkins's Avatar
After talking to a good friend last night, I've come up with what I think will be a great solution to fix this problem as well as having an adjustable undertray that will be easier to adjust than anthing that's currently available. It will literally take less than 1 minute to adjust, no panels to remove and no busted knuckles. I'll post some details once I get all the hardware and do a mock up. Also, the whole splitter/undertray assembly should be removable in just a matter of minutes.
Quick Reply: Fitting Ecklers nose - Poor quality.
