lube for rear end
Old 04-25-2013, 04:11 PM
opel
opel's Avatar
Default lube for rear end
Is this the lube I use in the rear diff?
I have this leftover from my C4 diff.
Old 04-25-2013, 04:25 PM
RX-Ben
RX-Ben's Avatar
If it doesn't have limited slip additive, you will need to add some. But should work otherwise.
Old 04-25-2013, 04:49 PM
opel
opel's Avatar
I believe it has the limited slip additive in it.
Old 04-25-2013, 09:31 PM
Solofast
Solofast's Avatar
I had a bad experience with that lube in a Dana 44.
Had a really good shop build it right, and was there when he did it, it was built tight just like I wanted. Put in that lube and in three autocross weekends it was slipping and the clutch packs wore out in short order.
Once a LSD clutch starts to slip wear is pretty fast. I've had better diff clutch life with the factory fill and the friction modifier.
Just my experience.
Old 04-25-2013, 09:33 PM
froggy47
froggy47's Avatar
That's what I use, no issues, has the friction modifier in it.
To lube for rear end
Quick Reply: lube for rear end
