Distorted Vision with Full Face Visor
I recently purchased my first full face helmet and the visor causes a distorted view. Is this common with full face shields or just because I bought the inexpensive Zamp helmet?
It isn't that noticeable looking out over a distance but i was wearing it today while blowing off the back patio and it made the concrete look wavy when I looked down. So far I have just run with the visor up since I got it but that kind of defeats part of the reason for having a full face helmet to begin with.
Definitely not normal............most visors can be replaced, so you should look into possibility of replacing shield with another one. You can research to see if generic replacement shields are available for your helmet, or if shields from a major manufacturer (Bell, Arai, Shoei, etc) will fit.
I have 2 Zamp helmets - SA2005 and SA2010.
Both are very nice helmets with absolutely no distortion when looking through the visor. I've had the SA2005 for 7 years now with original visor and it's still perfectly clear.
I just went out to the garage and tried them both - perfectly clear at all viewing angles.
I wear no-line bifocals, and when I looked down at the floor through the bottom of my lenses it was fuzzy because the bottom part of the lens is focused for close up viewing distance. When I looked at an old piece of newspaper it was perfectly clear at reading distance.
I got in the car and looked at the instrument panel and the wall in the garage and moved my head around, and at all angles the and distances the visor doesn't distort at all.
So....I think you may have a defective visor!!
Bob
Bob
Did you take the protective film off the visor??
I've heard lots of "distortrd" vision stories and most of them are because the protective film was still on the visor
I've got a huge helmet story in the May/June Vintage Motorsports magazine. One very important thing you have to keep in mind is that "All of the value priced helmets pass the same certification process as the expensive ones." You'll never know if the expensive helmets provide enhanced safety unless you do your own comprehensive testing."
Barnes and Noble no longer carries the magazine but you can get it for free here.
Richard Newton
Facebook
Richard Newton
I will check to see if it has a protective coating I missed. If not I will contact Zamp to see what they have to say about it.
Actually it was cool yesterday morning and I decided to wear it while I mowed. Turned out to be a great idea for protection from the wind, dust, and low limbs. I got finished mowing and just left it on to do some blowing.
I only buy cheap helmets & never had a bad shield.
Were you wearing polarized sunglasses under the shield by chance? A couple of years ago,I made the mistake of wearing my polarized Oakley's under my Simpson amber shield. I came out of the pits at Roebling, started through Turn 1, and almost puked by T2. Major double vision and distortion. Immediately made me feel like I was drunk and I do not get motion sickness very easily.
