PFC pads squeaking - but only at high temps
Old 04-13-2013, 09:35 PM
skyavonee
skyavonee's Avatar
Default PFC pads squeaking - but only at high temps
I've had the PFC Z-rated street pads for a couple months now. They're quiet at normal operating street temps, but they'll squeak when I start to really get some heat into them. It's more of a dull, subdued squeak, rather than a sharp, piercing squeak.
I'm slightly confused because I'm accustomed to pads that behave in the opposite manner to these, i.e. noisy when cold but quiet when hot. Should I ease up when they start making noise, or is it safe to power through? I doubt I'm cooking the pads, since that wasn't a problem for me with the oem C5Z pads that these replaced.
Old 04-13-2013, 11:28 PM
skxf430
skxf430's Avatar
Try bedding in the pads as it might help a bit. Here is a link how to bed them in.
http://zeckhausen.com/bedding_in_brakes.htm
Old 04-14-2013, 12:11 AM
Cliff Harris
Cliff Harris's Avatar
Normal for metallic pads.
Old 04-14-2013, 01:43 AM
skyavonee
skyavonee's Avatar
Already did it once when I first installed them, but I can try it again when I have the time.
Old 04-15-2013, 02:30 AM
trackboss
trackboss's Avatar
I have used pfc quite a bit and found thier race pads to be pretty street friendly in terms of providing good stopping power when cold and being relatively quiet. Rotor friendly as well. I'd say don't worry about it.
Old 04-15-2013, 12:40 PM
63Corvette
63Corvette's Avatar
Consider yourself lucky! I didn't think you could GET PFC-Z rated pads any more. Where did you get them? I ran them 15 years ago, but now I run Stoptech Street Performance pads for both the street (excellent cold bite) and light track duty (MSR Cresson, not Road america), they are good for 1300 degrees F.
Old 04-15-2013, 03:12 PM
skyavonee
skyavonee's Avatar
It took some searching, but I eventually found them at Rotorsandpads.com. They were still available last year - P/N 0731.10 and 0732.10
How do the PFC-Z compare with the StopTech Street?
Old 04-16-2013, 12:05 PM
63Corvette
63Corvette's Avatar
The Stoptech Street Performance pads are 15 years newer technology!
Old 04-16-2013, 04:11 PM
bags142
bags142's Avatar
You can get the PFC Z's from o'riley or autozone.. just gotta special order them
Old 04-16-2013, 04:12 PM
bags142
bags142's Avatar
Ok, so does that make them better cause they are newer? Or are they actually better?
Old 04-16-2013, 05:03 PM
63Corvette
63Corvette's Avatar
To ME the Stoptechs work better. The PFC-Z pads were a good street pad however, they were never intended for racetrack usage. I'm sorry I don't know what the max temperature was for the Z rated, but I don't believe it is 1300 degrees F. and my Stoptech Street performance pads do work very well at the temperature, as well as at normal (cold) street ambient temperatures.
Old 04-17-2013, 11:45 AM
bags142
bags142's Avatar
Ok. I like the Z's for street use, but I have limited use on street pads. But, I find them very good. Track use, it took a few hpde's, but I went to the 99 compound.
Thanks for the info, I may look at trying the stoptech's after these wear out
To PFC pads squeaking - but only at high temps
Quick Reply: PFC pads squeaking - but only at high temps
