Lowering bolts
Old 04-13-2013, 02:32 PM
383 Z06
Racing
Support Corvetteforum!
383 Z06's Avatar
St. Jude Donor '09
Default Lowering bolts
I just ordered the Johnny O'Connell stage one shocks/sways/end links from CCA. I am currently lowered all the way on aftermarket WCC bolts. I do HPDE about once a month or so, I don't daily drive the car so I'm not worried about the harsh ride. My question is do I need to raise the car a little in order to maximize the potential of the shocks and sways? If so how much?
Oh and also, when I lowered the Z51 suspension all the way initially I damaged one of the shocks. Maybe this was because I slammed it all the way. At the time I was going for the look, now I'm looking for function. This makes me hesitant to keep it this low on the JOC shocks.
Thanks for the help
Old 04-13-2013, 02:50 PM
avizandum
avizandum's Avatar
My Z51 came from the factory with the front bolts 4 turns up from bottomed out and the rears 1 1/4 turns up. (I think that's about where the Z06 comes from the factory as well.) So there's only 1 1/4 turns down while maintaining factory rake.
I'd set yours to that and measure from the a-arm to the top of the spring as precisely as you can and record those measurements.
Start from there and tweak per upcoming advice.
Old 04-13-2013, 09:33 PM
383 Z06
Racing
383 Z06's Avatar
St. Jude Donor '09
Sorry correction....I have WCC bolts...I edited above
Old 04-14-2013, 11:39 AM
davidfarmer
davidfarmer's Avatar
It's hard to say, but I'd raise it back up a bit. I generally like to stay close to OEM minimum ride height, and not below. That varies from car to car of course, but you are likely 3/4" or so below that. The suspension angles just don't work as well.
To Lowering bolts
Quick Reply: Lowering bolts
