Aluma tilt versus Kwikload trailers
Old 04-09-2013, 11:51 AM
QUIKAG
QUIKAG's Avatar
Default Aluma tilt versus Kwikload trailers
Looking for a trailer and have narrowed down to these two brands. Any comments or advice either way? TIA!
Old 04-09-2013, 07:33 PM
MarkDFW
MarkDFW's Avatar
Old 04-09-2013, 10:49 PM
trapp
trapp's Avatar
I have a Kwikload 20 footer and I love it....only issue that I have heard of is that you can't put to much weight up on the front...such as a large tire rack full of tires because it will cause the trailer to pop up alittle when your backing the car off. I strap 4 tires/wheels on the front of mine and I don't have any problems but if you have more then that I could see it happening...
I can load my vette and strap it down in about 10 minutes with no help! I would highly recommend it!
Tom
Old 04-10-2013, 10:38 AM
bsalie99
bsalie99's Avatar
I also have the 20 ft Kwikload and it is the best. I have never put any weight on the front as mine came with the rock shield ( which is the only part that is cheaply made) It loads the car effortlessly and I have to do it all solo. It was worth the cost to get one
Old 04-10-2013, 10:51 AM
JMBLOWNWS6
JMBLOWNWS6's Avatar
Kwikload 20ft trailer. Best trailer on the market for lowered cars. I had them move out the rear D rings and button head bolts so lowered C6's with a front splitter would not touch.
To Aluma tilt versus Kwikload trailers
Quick Reply: Aluma tilt versus Kwikload trailers
