Tire Data Calculator
6th Gear
Hello All,
I've just finished the updates to the Tire Data Calculator.
http://bndtechsource.ucoz.com/index/...alculator/0-20
Now not only can you can input tire & rim sizes, you can input air pressure, vehicle speed and corner loads.
The outputs are as follows:
Output Spec. Data Result Tire 1 Result Tire 2
Spec. Design Rim Width
(manufacturer’s measuring rim)
Spec. Tire Outer Diameter
(at spec. air pressure and no load)
Spec. Tire Section Width
Spec. Tire Section Height
Spec. Static Load Radius
(@ spec. maximum load and spec. air pressure)
Spec. Tire Rolling Circumference
(@ 60 km/h, spec. load and spec. air pressure)
Spec. Dynamic Rolling Radius
Spec. Tire Stiffness Rate
(@ spec. load and air pressure)
Tire Air Volume
Output Vehicle Data Result Tire 1 Result Tire 2
Vehicle Tire Section Width
(@ vehicle load, speed and air pressure)
Vehicle Tire Section Height
Vehicle Tire Deflection
Vehicle Tire Rolling Circumference
Vehicle Dynamic Rolling Radius
Vehicle Tire Stiffness Rate
Contact Patch Width
Contact Patch Length
Contact Patch Area
Speedometer Reading
(Tire 1 is assumed accurate)
Tire Suspension Comfort Value
Please let me know your feedback.
Thanks,
bndtechsource
Tire Air Volume
Contact Patch Width
Contact Patch Area
Speedometer Reading
Thanks,
bndtechsource
