A6's... would you run these? pics inside.
Old 02-20-2013, 12:53 PM
Mike.D
Mike.D's Avatar
Default A6's... would you run these? pics inside.
I bought the A6's from a track owner who said I'd get about 3- 4 tack days out of these. After completing my second track day what do you guys think about running these fronts? I do NOT know how many times they were previously H.C'd.
Here are the rears..
Old 02-20-2013, 01:20 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
track records have been set on worse looking ones
run 'em
Old 02-20-2013, 01:28 PM
crease-guard
crease-guard's Avatar
They've got some life left in them. I run mine until the groves are about gone. That's the point even I notice they aren't gripping any longer.
Old 02-20-2013, 01:46 PM
Werks
Werks's Avatar
Nothing wrong with those! I think that you are probably concerned about all of the rubber chunks stuck all over the tires. Just stay out of the marbles when coming off the track with hot tires to help avoid that. When these tires get hot literally everything sticks to them!
Old 02-20-2013, 01:53 PM
Mike.D
Mike.D's Avatar
ok great news. What are those small slashes in the rubber?
Old 02-20-2013, 02:20 PM
crease-guard
What's the date code on the tires? If they are cracking from being out in the sun them you might not want to run them if they haven't been stored properly or are too old.
Old 02-20-2013, 02:46 PM
alextz
alextz's Avatar
they look ok.....not sure you will get 4 track days.....I would flip them on the rim (looks like the previous owner didnt have all that much camber on the car)....will be a little pushy till the camber wear sets in
Old 02-20-2013, 03:27 PM
Mike.D
Mike.D's Avatar
i will look today, but i know they were not stored in the sun. Nor are they now.
Old 02-20-2013, 03:52 PM
Han Solo
Han Solo's Avatar
I've had better looking A6s cause me to bust my *** but not from coming apart. They just got too greasy after 15 minutes of track time and pushed out. I was partially at fault for not heading the warning signs. That was my one and only time buying scrub A6s and they were sold as having 3 to 5 heat cycles on them. From that point on I went back to buying new V710s.
That said I would not trust those tires with the little cracks on the edge and I sure as heck would not flip them and put the cracked edge on the outside. My personal opinion.
Old 02-20-2013, 05:01 PM
froggy47
froggy47's Avatar
I would flip them & use them up. But I can feel a tire going off on a lap, not sure if you can.
Old 02-20-2013, 05:40 PM
V8 Juice
V8 Juice's Avatar
I know places I can get new tires; I don't know places I can get a new me. How did they feel when you drove them for 2 days? What is the condition of the existing back tires? I don't run old and new tires but heck, some guys run tires if they hold air for a full session!
Old 02-20-2013, 08:08 PM
Kubs
Kubs's Avatar
Received 1,753 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
There is a shiny metal tread under the black rubber one. Its not as fast as the rubber one but it works. When that one is gone then the tire is done.
Yours look great, keep running them!
Old 02-20-2013, 08:43 PM
froggy47
froggy47's Avatar
Here are some that are done. The white stuff is just dirt/sand I drove thru when I got home. Good that it didn't rain.
I would have really had a handful. Teaches car control.
JK, don't try this at home.
Old 02-20-2013, 10:38 PM
l98tpi
Max G’s
l98tpi's Avatar
same experience with the so called 3 to 5 heat cycles. Learned my lesson. Only new from now on.
Old 02-21-2013, 02:03 PM
moespeeds
moespeeds's Avatar
I'm with Froggy. Run'em until you see belts. Of course they are going to go off, but you ain't racing, just keep it on the track. They look fine to me.
Old 02-21-2013, 11:56 PM
Mike.D
Mike.D's Avatar
Thanks for all the input fellas. I'm not racing, and I'm definitely not as good as most guys out there... So I think I'll run them for another track day or so. Take that $1600 that I would have spent and upgrade the heads .
To A6's... would you run these? pics inside.
Quick Reply: A6's... would you run these? pics inside.
