Ideal coolant temp for roadrace 92
Hello all
I am in the process of overhauling my 92 this winter for mainly roadracing. I dont have much done to the motor but ARH headers and a hotcam kit. I am installing my Dewitts 2 row radiator this weekend and wondering if there was anything else I should do to maintain ideal racing temps? ECM fan reprogram,Thermostat,Manual overide switch etc?
With the Dewitts and one working fan (long story) mine has seen 270 by the digital readout. That was a 100 degree day in the humidity at VIR. Found the debris that was partialy blocking the lower area and it never got higher than 260.
I don't have an oil cooler and a stock pan so I was seeing 290 on the oil temp.
Don't know about the new combo (road race oil pan), If I don't see the oil temps closer to the water temp I'll be adding an oil cooler. I only run 15 - 20 min sessions.
Well the radiator is a good idea. I'll tell you what I have for my dedicated C4 race car and you can pick up on that:
- dedicated oil cooler with its own fan. Lower oil temps equals lower temps overall. Manual switch to turn on and off.
- manual switch for secondary fan so I can run it when I want.
-160 degree thermostat with 8 drilled holes in it.
-air dam with large air opening boxed in to the rad a la stock car.
- hood vents on the top and side of the hood to get air out.
- water wetter.
with all this I still get 230 on hot days (70 degrees and up to hi 90's) with both fans running. If its below say 60 degrees F, I may run around 210 to 220 degrees. That's all pretty hot but normal for a C4 mostly I think because of the cramped engine bay. I don't run an LT1 motor so if you are, it would be a good thing to install a meziere electric water pump and get that GM thing out of there. Its really important to vent that engine bay.
- water wetter.
I just finished an article on cooling systems. It should be out next month. I talked to a lot of engine builders and radiator people. The consensus is that you want the water temp between 210-dgrees and 220-degrees.
You can go higher but the bhp gain is minimal.
Richard Newton
Car Tech Stuff
Richard Newton
Car Tech Stuff
Cruising
I have a similar set up in my 93 6pd lt-1. Lt headers, hot cam kit and injectors. I had the ecm programed for the cam and headers plus to turn on the fans at 175 degrees. I also placed in a lower temp thermostat. Stock the water temp. ran 230-240 even on cold days for a 30 min hpde. Now around 200-210 on a hot day.
Max G’s
Mine will run up between 200 and 220. I run 180 thermo, wash the radiator annually to remove any debris or dirt, run about 70% water and 30% e-glycol, and usually a bottle of Purple Ice.
I usually see 220 on my 92.
I have a manual override switch on the fans (very easy install).
Just a note on the manual switch - if you install one, you will get a code 28 (Quad Driver), no check engine light though.
Just ignore the code, clear it if you want. That Quad driver is just looking at voltages in the fan circuit.
